SC:anyone running an intercooler?
Eri S2K, your setup looks great. I'm surprised more people don't use a FMIC for the same reasons turbo guys don't use air/water setups. I'm not saying one is superior to another, however though there is more piping in FMICs they don't have the heat exchanger, pump, and/or reservoir to have to deal with and appear (at least superficially) simpler to deal with.
Originally Posted by xviper,Jan 17 2006, 07:51 PM
Putting the two side by side isn't a good way to determine the coolant volume inside. I drained and collected the coolant when I pulled the hoses off the old stock rad. When I got the Tech 2 rad installed, I could not get all the coolant that I drained back in. The Tech 2 may have a bigger exterior dimension, but the coolant tubes through the fins and the spaces on the ends do not have nearly the volume of the little stock rad. I had about 1/2 to 3/4 of a pint left over.
I noted the intake air temp using my ECU display last summer with the stock rad. Next summer, I can compare those readings with the Tech 2 rad in place.
quick question. If you run a air/air intercooler set up with ctsc or vortech kit. Will there any boost lost ? for example if the ctsc come standard 5.5psi. Will it still boost 5.5psi with a air/air intercooler set up instead of the aftercooler ?
This is not unlike those who started off with a Comptech without an intercooler and then adding an intercooler. The extra volume of the intercooler and accompanying hoses and piping dropped the boost pressure by about 1/2 to 1 psi. Owners were compelled to buy the smaller pulley to get that pressure back. As huge additional area like that of an air/air intercooler would create a bigger pressure loss.
Originally Posted by xviper,Jan 22 2006, 01:34 PM
On a dyno pull where you are doing a steady run up to redline in a higher gear like 4th, no, you won't lose much boost, if any at all. However, in the real world where you are going through the gears quickly, I believe you will not see max boost as you did with the stock setup. Every time you change gears and close the throttle, the BOV will release some intake pressure. Also, first gear goes by so fast, that the blower will have a more difficult time compressing the larger air volume in the same amount of time. By comparison to a car on a dyno, 2nd and 3rd gears will go by pretty fast also since you are starting off at or near VTEC rpm after the change.
^ how did you lose 4.5 lbs omg thats alot. I never heard of a turbo set up losing boost like that.
Originally Posted by Eri_S2k,Jan 22 2006, 05:41 PM
I have the 10psi SOS Pulley and at the Dyno the Boost Gauge and the Boost signal in the Dyno Readys 10psi EXACTLY!
So i dont have any Boost loss
History and documented reports indicate a pressure drop anytime the intake volume is increased like when an intercooler is added or an intercooler is increased in size.
dan_uk
Feb 5, 2014 04:50 PM
joes sled 2000
Apr 15, 2012 09:44 AM
