SC making some weired noise.
Old Feb 10, 2006 | 09:12 AM
WindchaserS2K's Avatar
Default SC making some weired noise.
SC making some weired noise. Is the bearing about to go??? but the car still running strong. Any advice welcome
Old Feb 10, 2006 | 09:54 AM
folex187's Avatar
More people will help if you describe the noise a little better.
Old Feb 10, 2006 | 10:32 AM
It sounded like somthing is loose inside the Blower
Old Feb 10, 2006 | 12:15 PM
folex187's Avatar
If it's a comptech mine used to make different sounds at different temps. Every Paxton blower I've ever heard does that. I would doubt they you fried the inside unless you don't change your oil regularly, have an oil restriction, or run crazy boost.
Old Feb 10, 2006 | 01:11 PM
Is a Vortech SC running 9lbs and I changed the oil every 5000 miles, so you think is normal then right?
Old Feb 10, 2006 | 04:07 PM
olskodumie's Avatar
vortech recommend change oil every 3000 miles
Old Feb 10, 2006 | 04:14 PM
So you are saying by changing oil every 5000 which is 2000 more then what they recommend will hurt the blower bearing????
Old Feb 10, 2006 | 04:17 PM
olskodumie's Avatar
i'm not sure, mine is about 300 miles over and its starting to sound different. i hope its not bad bearings. we'll be screwed
Old Feb 10, 2006 | 05:04 PM
Damn!!!!!!!!!!!
Old Feb 10, 2006 | 05:11 PM
Asura's Avatar
The oil will burn especially with more boost. I change mine every 1750 miles. Its cheaper and less time consuming than rebuilding a motor or SC. The additives usually don't last that long either.
1750 might be excessive but 5000 is a long time. Do you consume any oil?
