sc no boost
Old May 21, 2010 | 02:55 PM
slicko9's Avatar
Default sc no boost
installed the comptech aftercooled setup this past weekend. I feel a noticable difference. However, by boost guage is not reading any positive vacuum. We tried a few different places on the intake manifold but are still getting no positive vacuum. No where near the 4 or 5 lbs that the pulley is rated for.
I can hear the whine of the sc @ low rpm
I can feel a difference, but maybe I'm not getting as much as I should be.
Old May 21, 2010 | 02:57 PM
Slows2k's Avatar
Is it a mechanical boost gauge?
Old May 21, 2010 | 03:01 PM
slicko9's Avatar
Mechanical gauge
Old May 21, 2010 | 03:03 PM
Slows2k's Avatar
Take the hose off and either blow in it with your mouth or a air line from a air compressor. Need to make sure the gauge works.
Old May 21, 2010 | 03:05 PM
slicko9's Avatar
Tested with two different vacuum gauges.
Old May 21, 2010 | 03:43 PM
slicko9's Avatar
At idle I am at 20 in vacuum
At partial throttle it drops to ten
And then full throttle I am at 0
Old May 21, 2010 | 03:50 PM
Slows2k's Avatar
Full throttle at what RPM.. Peak boost doesn't occur until max RPM
Old May 21, 2010 | 03:51 PM
slicko9's Avatar
Even through 9200 rpm I'm not getting any positive.
Old May 21, 2010 | 04:03 PM
Slows2k's Avatar
Is the belt tight?
Old May 21, 2010 | 04:07 PM
slicko9's Avatar
Yes. There's very little play
