sc Project
i hear you should change the clutch at the same time because they have to remove the SC to put it in. doing it at the same time as the SC install will save you labor costs/your own time if you choose to do it yourself.
Originally Posted by ENTHRALLED,Jul 22 2007, 09:47 PM
I'm running a Vortech kit and have unpgraded my Clutch and swapped out my spark plugs to NGK 7173.other then that I put 19k miles on it so far without issue.
Swap plugs to the NGK 7173 coppers every OTHER oil change.
Gap them to .034
Most people run synthetic oil also.
No need for gauges but they are nice to have.
Maybe get an extra SC belt
Check your setup weekly for loose fittings, oil levels and leaks.
Keep your ail filter clean
Gap them to .034
Usually the platinum ones come pregapped. Most of us are running copper plugs and changing them more often for better performance.
You can get a plug gap tool for a buck or two at your local auto parts store.
It's old school stuff
fltsfshr
fltsfshr
Originally Posted by nightcrawler7188,Jul 23 2007, 04:10 AM
n00b question, but how do you "gap" plugs? i thought you use them as you buy them...
Wire measure is best to test gap.
