School me on gauges
Sup fellas, how about we start a new class Gauges 101
I'm going to be the first to register.
Well, from questions, searches, etc. I have come to acceptance that I WILL need gauges. Only problem is that since I have been trying to avoid them, I haven't learned much about them.
Here are my Q's
1. When purchasing gauges, I'm looking into the Defi blue racer, will any additional parts be needed to accompany them? I have read things such as sensors and what not.
2. Memory? Why would I want to know what already happened? What good will it do for me? (This one is what I'm really confused on)
3. How do you read them? What is normal? What happens if the gauge reads beyond normal while driving, would you pull over right away? If so, then what? Get it towed?
4. If you can only have two gauges, what would it be? Boost and oil temp?
Thanks
I'm going to be the first to register. Well, from questions, searches, etc. I have come to acceptance that I WILL need gauges. Only problem is that since I have been trying to avoid them, I haven't learned much about them.
Here are my Q's
Thanks
I'm going to be running boost and exhaust gas temperature. Only because I have done some research and found if yo uare only running 2 gauges these can identify the most.
The memory thing is good if you want to know that you are over boosting or something is spiking and you want to adjust it.
Other then that I am quite interested in what the vets have to say. If I'm wrong feel free to tell me but from my research that is what I have learned.
Here are my Q's
Thanks
Here are my Q's
Thanks
2. Memory is good to have so you can see peak numbers. As stated before, its not safe to watch your boost gauge when your WOT (should be watching the road).
3. You read them by uh, looking at them
. Do a search for what is normal on the different kinds of gauges. I posted my oil temp,oil press, water temp, and EGT under a number of conditions some time back. If something like oil pressure goes dead, yeah your going to want to immediatly check it out. The point of them are situtations like that.4. For turbo Boost and oil pressure. For SC, Boost and oil pressure
Originally Posted by Spec_Ops2087,May 7 2007, 02:11 PM
1. No idea, I don't own defi
I just brought up defi because I am looking into them, but just gauges in general. I want this thread to be useful for those that have questions as well. Thats why I didn't get into specifics of size of turbo, etc.
But regarding #2. So i see it afterwards, what is that going to do for me? So lets say I'm am at WOT, boost and/or oil pressure, sky rockets, but the car is still running fine afterwards, am I suppose to go get it checked?
Originally Posted by BulldogS2,May 7 2007, 05:21 PM
I knew it wouldn't be long before you chimed in
Another reason for it is tuning boost controllers. You can change some settings, WOT run, check your gauge's memory, and play with the settings some more until all is well.
oil pressure, boost, and exhaust temp are the most important. exhaust temp gauges really help because it can tell you if you are running lean or rich. if temps get hot your running lean and temps are cold you are rich. wideband a/f guage is also good if you would want to do street tune to work out bugs, but if it is tuned properly you wont need one.
Originally Posted by 2QYK4U,May 7 2007, 06:51 PM
An oil pressure gauge is the single most important gauge. Make sure that you include this gauge with your setup.
What does oil pressure tell me?
Is it hard to do the install of these gauges?
