ScienceofSpeed introduces MAP sensor for 2006-09
As many know, the 2006-09 Honda S2000 uses a proprietary MAP Sensor body. In the past, we have used the K-series MAP sensor requiring customers to modify the sensor housing to fit the stock plug.
We could not justify the very costly process of molding a housing specific for the 2006-09 until Hondata released the Hondata FlashPro for 2006-09. This engine management tuning device is a fantastic advance for the 2006-09 S2000 allowing customers to tune fuel, ignition, and VTEC while retaining the factory ECU - all at a very attractive price of $695.00. As many of these cars with the FlashPro will be using supercharger and turbocharger systems above 10 PSI requiring an upgraded MAP sensor - we've responded with the release of the ScienceofSpeed 4 BAR MAP Sensor for 2006-09 Honda S2000.
This is the only sensor offered that allows true plug-and-play installation. No grinding of the senor required for fit or wire modifications required. In addition - the sensor is already available in the Hondata KPro and FlashPro software as an optional sensor requiring no calibration. Installation takes less than a minute (remove stock sensor, replace with new sensor) and setup in the software is a simple drop-down selection - allowing users to be ready to tune in less than two minutes with the new sensor - fantastic!
for more information:
http://www.scienceofspeed.com/products/eng...or/06-09_S2000/
cheers,
-- Chris
cheers,
-- Chris
Originally Posted by CROD,Dec 22 2009, 04:17 PM
SOS does it again
Can't wait to get flash pro and up the boost!
Great Job, now all you have to do is figure out how do you get a wideband hooked up to it the ECM and the KPRO will become a fossile.
HP tuners and other have a nice OBDII logger with 0-5V input for a wide band that is very nice without haveing to purchase another device like the Innovate logger.
Originally Posted by Chris@SoS,Dec 29 2009, 10:45 AM
Do you have a Euro spec S2000 in the US?
-- Chris
-- Chris
so I need to first wait until they release the flashpro for eu specs
