ScienceofSpeed introduces MAP sensor for 2006-09
I wanted to let you know that the MAP sensor for 2006-09 Honda S2000s have been shipping. This is the ideal solution if you are using forced induction systems for any 2006-09 Honda S2000.
http://www.scienceofspeed.com/products/eng...or/06-09_S2000/
A customer recently tuned his ScienceofSpeed Supercharger System with this new MAP sensor and Honda K-Pro to produce over 500 wheel horsepower:
https://www.s2ki.com/forums/index.php?showtopic=769559
We also have MAP sensors for 2000-05 as well. Considering a high boost supercharger or turbocharger system? Don't forget the MAP sensor. Easy plug-and-play installation compatible with any engine management system:
http://www.scienceofspeed.com/products/eng...or/00-05_S2000/
thank you again,
-- Chris
thank you again,
-- Chris
We recommend these if you plan on making 10 psi or more of manifold pressure. The stage 2 systems produce around 9.5 psi, and this is not needed. If you plan on expanding in the future however, it's a good idea to buy this now, and have the ability to expand with out having to return much of the calibration.
take care,
-- Chris
take care,
-- Chris
hyperpm
May 15, 2003 05:36 PM
