Should I run thicker oil for the dragon?
Old Mar 29, 2011 | 02:59 AM
NFRs2000NYC's Avatar
Default Should I run thicker oil for the dragon?
Whats up guys,
I'm heading down to the dragon in two weeks, and am changing all my fluids. Should I go with a heavier weight for the trip? I normally run 10w30 (greddy turbo) but thought maybe 10w40 would benefit me. Any advice?
Old Mar 29, 2011 | 04:37 AM
s2000442's Avatar
It is the first number that is the weight of the oil not the second. 10w30 or 40 would be fine. Not sure you should run any heavier with a turbo like 15w or 20w anyway.
Old Mar 29, 2011 | 06:26 AM
Torque Obsessed's Avatar
In the Greddy turbo kit thread I think Chris suggested a different fluid weight than you're using. I went with 5w40 Redline when I was Greddy'd. Now I've got several gallons left to sell, since I'm SC'd...
Old Mar 29, 2011 | 06:35 AM
9krevvin's Avatar
I actually called GReddy and they told me to run the factory weight oil. (10-30) They just told me to use synthetic oil only. I have to disagree with s2000442 the second number is the thickness and the first number is the cold start thickness.
http://www.machinerylubrication.com/Read/171/oil-can
Old Mar 29, 2011 | 07:18 AM
s2000442's Avatar
^yep you are right, I always tried to go with a 40 weight because it does not thin as much under higher heat.
Old Mar 29, 2011 | 07:40 AM
D1sclaimer's Avatar
The owners manual even says you can run 5W-40. I think in Europe or Japan, it is the suggested weight for stock cars.
Old Mar 29, 2011 | 09:03 AM
Wow, wish I'd talked to you before I bought all that 5w40 Redline synthetic... Good to know.
Old Mar 29, 2011 | 03:14 PM
So 10W40 wouldn't harm anything right? I've never actually had any issues running 10W30, just wondering if 10w40 was a better idea.
Old Mar 29, 2011 | 03:49 PM
camuman's Avatar
i run 10w40 in my car. as long as it doesnt see freezing temps u can increase the first number.
Old Mar 29, 2011 | 09:59 PM
You mean decrease right? I live in NJ, and I do see freezing temps (although I almost never drive the car in the winter) but I also don't want the inability to start it. However, I will probably change my oil when I get back from the dragon, so it will only be in there for this trip.
