Silicone duct hose for cold air intake?
I've been thinking about ways to route a cold air intake for a supercharger setup (applies for turbo guys too). Instead of cutting aluminum tubing and getting creative with the routing, has anyone used a silicone duct hose? I found one that has a very smooth inner surface built specifically for airflow applications. Routing a hose will be tons easier, instead of mating several aluminum pipes together. It's a 2-ply design and can withstand 550F.
Anyone tried this out?
I looked into that as an option when I did my CAI. It seems like it would work fine, though I couldn't find silicone hose as big (diameter) as I wanted. And I wanted the bling, so I went with polished aluminum piping.
I bought some 3.5" duct from http://www.hrpworld.com/index.cfm?tp...action=product
Datasheet here: http://www.hrpworld.com/client_image...pdf_3171_1.pdf
I plan on hooking this up directly to the inlet of my blower (paxton 1200). The duct is rated at 29 in/Hg of vacuum (~14psi). I've seen people hook it up directly to their turbo inlet without issue. The inlet pressure should be less than the compressor side. I'm running 9psi of boost; I expect about half of that for inlet pressure.
