Sleeved block and heat ?
Old Jul 22, 2010 | 01:30 PM
drhess06259's Avatar
Default Sleeved block and heat ?
Ok so I just built my block and put darton mid sleeves in but I have noticed that the motor itself is hotter to the touch after even normal driving. Is the common with sleeved blocks? I still have an operation temp of 180 ish and iat of high 90's low 100's but it just seems odd the motor is hot to the touch as it didn't used to be this hot. Like I can't even touch anything after a drive.
Old Jul 22, 2010 | 02:05 PM
secondhandloser's Avatar
It will run hotter w/ a sleeved block... But was your motor ever touchable after a drive?
Old Jul 22, 2010 | 06:54 PM
Muscle Cars Blow's Avatar
Motors in general should be hot to the touch. Combustion is over 2000 Degrees.
Old Jul 22, 2010 | 09:39 PM
I understand they should be hot to the touch just this is a lot hotter then I remember
Old Jul 23, 2010 | 08:56 AM
Just watch your water temps. I can't imagine feeling much of a difference, but I suppose it is possible....
Old Jul 23, 2010 | 10:11 PM
I can't even take off my oil cap because it's too hot to touch
Old Jul 25, 2010 | 09:09 AM
bois2k's Avatar
Dont say that mines getting sleeved
Old Jul 25, 2010 | 10:02 AM
TRBOKEV's Avatar
The Darton sleeves are closed deck and dont cool as well as the open designs like Benson / OEM.
Old Jul 25, 2010 | 03:37 PM
What's the difference between closed and open deck sleeves?
Old Jul 25, 2010 | 05:16 PM
teamvalorracing's Avatar
^google.
-closed deck is solid across the top of the block from the outter edge to the combustion chambers with only little drilled holes to allow coolant passage. open deck has an open water cavity all the way around the piston sleeve.
180's are great water temps. a little cold for max power(195-ish), but fantastic for dd.
