Small Air Filter?
Old Jul 6, 2012 | 06:17 PM
herecomesboost's Avatar
Default Small Air Filter?
My new setup consists of a Full Blown sidewinder manifold/T4 6262 turbo; there isn't enough space between the turbo inlet and the frame of the car to run a traditional 3" filter. What are you guys running? What do you suggest? At the track, I'll run filter-less for sure, but I'm looking for a street solution (driven a few times a month on the street). I appreciate the responses. TIA
-Kyle
Old Jul 6, 2012 | 08:14 PM
Booztin's Avatar
-Kyle
when I used the full blown mani I was able to use a k&n filter. It's about 3-4 inches tall if that and still had plenty of room. I dono if your turbo sits diffrently then mine did though. I was using a gtx35 at the time.
Old Jul 7, 2012 | 01:53 AM
Phill24's Avatar
i went to pepboys and bought an apc short filter not the best filter in the world performance wise but it works for what i need it to do
Old Jul 7, 2012 | 05:29 AM
s2klariat's Avatar
I know they are fugly but you could probably get away with using one of those "Dome" filters like they use with the Greddy kit.
Old Jul 7, 2012 | 05:38 AM
camuman's Avatar
I have run filter less for a year and 5k miles.
Old Jul 7, 2012 | 08:58 AM
g352s2k's Avatar
Don't use the dome filter.... It drys up and crumbles, also it could get sucked into your turbo. Your local auto store prob has those short spectre shortie intakes and they work fine.
Old Jul 7, 2012 | 03:18 PM
spectacle's Avatar
I wouldn't recommend that
Old Jul 7, 2012 | 03:44 PM
Maybe Full Blown's design has changed? I only have a few inches between the turbo inlet and the frame of the car (and I'm using the more compact 'e' cover).
I appreciate the responses. I may try to run a 90 degree silicone elbow through the frame (behind the headlight) and run a small section of pipe to locate the filter behind the front bumper.
Old Jul 7, 2012 | 04:22 PM
neeman77's Avatar
Its pretty tight behind the headlight, good luck!
Old Jul 7, 2012 | 05:09 PM
Torque Obsessed's Avatar
I was able to get 3.5" aluminum piping through there when I had my SC. Had to cut away some of the metal around the opening, and thinned out the headlight support bracket. Worked fine though... And was pretty easy to do with some sheet metal shears.
https://www.s2ki.com/s2000/topic/880...old+air+intake
You could also try one of those mesh screens. I think Forged sells them.
