Smaller pulley, ACT PP, and retune #'s
I would have expected the number to be a bit higher also, but numbers can vary quite a bit from dyno to dyno.
Do you have any idea what your IAT's looked like or how much timing was pulled up top?
Yeah the peak power is a little short for the 15psi but sometimes the boost readings aren't accurate either on the dyno I found. It could be pushing less then that which I think it is based on the 3.8" pulley size. I bet your actually only making 11-12psi, which would be really excellent at 370whp. The 218 trq is obviously an F20 your running? Thats a typical number for the engine.
A 3.2" pulley would net you about 15psi and get you to 400whp on that 1220 blower.
Nevermind, just saw it was a v2 vortech blower, so your boost is correct for your pulley size, your just down on power a bit. Likely a conservative tune, which is fine as long as its running well and feeling good. You want it to last! Must have mixed your set up with someone else on the blowers.
I believe he mentioned my temps were all very good and I also believe he said he didn't pull much timing up top at all and that there was no detonation or knocking at all. I'm paraphrasing
Doing the banjo bolt replacement and possibly ap2 retainers and keepers to help make that a reality
