Smaller Pullies
Old Dec 30, 2009 | 11:46 AM
Moddiction's Avatar
Former Sponsor
OK either I suck at searching or something but I can't fnd the part number or size for stock Vortech AP1 sc pulley. Need the stock 7 lb boost pulley.
Think I saw but want to make sure and if anyone has a part number for it.
Old Dec 30, 2009 | 11:53 AM
hazmat's Avatar
so what size would i get to for 11psi on an ap2 motor and where can I get it? I have a v3 but i think its the same unit as the v2 with the self oil lub.
Old Dec 30, 2009 | 12:00 PM
Moddiction's Avatar
Former Sponsor
Ok so found some info but hopefully someone can confirm this before I just go ahead and order it.
This is what I think I need but not sure if the pulley was 6 rib or not.
This is the part number I found on Vortech's site.
2A036-500 5" 6 rib pulley.
http://www.vortechsuperchargers.com/produc...ion.php?pvk=289
Old Dec 30, 2009 | 01:31 PM
nsx_bob's Avatar
this might help you.
https://www.s2ki.com/forums/index.ph...c=305897&st=0&
Old Dec 30, 2009 | 01:35 PM
nsx_bob's Avatar
Hey sideways what do you think about building the Vortech v2 unit with abec 9 ceramic berrings and chainging the impeller to a t-trim impeller? Is your Vortech unit still stock?
Old Dec 30, 2009 | 05:37 PM
Sideways's Avatar
The bearings in a stock V2 are not big enough. They have an upgraded Heavy Duty T-trim with larger bearings. Even so, the T-trim can be maxed with an S2000.
I have been looking at the V7 YSi with more capacity.
Old Dec 30, 2009 | 09:11 PM
nsx_bob's Avatar
ooo nice one. I see that it fits most Vortech brackets. Will it fit the one on the s2k kit?
Old Dec 31, 2009 | 12:23 AM
Sideways's Avatar
No.
Old Jun 29, 2017 | 01:33 AM
RolanTHUNDER's Avatar
Hey guys, is this pulley a good quality one? According to the pulley size/rpm chart, it is safe for 8800rpm shift speed but I'd prefer a 3.8" for full 9000rpm "red flash" shifts:
https://www.summitracing.com/int/parts/vor-2a036-361/applications/?ibanner=SREPD2&retaillocation=int
Old Jul 1, 2017 | 05:40 AM
Sideways's Avatar
Call Lee at ASP and get whatever size you want. The ASP design is superior to the factory design.
1 936 825 3117
