SOS clutch
Originally Posted by ILoveMYHonda1984,Sep 27 2010, 11:59 AM
I installed the SOS clutch on a local members car, we love it. Smooth as stock with a close to OEM pedal effort. I am sure that it can handle anything you can throw at it with a kraftwerks kit. I say go for it.
OK but has anyone tried it with the Kraftwerks high boost kit i know it would feel great stock but will it actually be able to hold the power and not die out in a couple of months?
Try giving KW a call and ask if the following will be sufficient with their high boost kit?
"The ScienceofSpeed Sport Clutch for Honda S2000 is rated at 300 lb/ft at the flywheel (approximately 255 lb/ft wheel torque or 400+ wheel horsepower)"
Originally Posted by JawKnee,Sep 29 2010, 01:22 PM
I'd be surprised if the KW high boost kit will work with the stock clutch. In fact, they suggest/recommend upgrading it for their high boost kits. For what it's worth, I only had 34k miles on my '05 when I installed the SOS Base kit (~6 psi) and my clutch slipped right away in higher loading gears like 4th.
SOS kit will hold KW hi boost. i think the SOS clutch can hold anything under 300wtq, which the kw hi boost wont touch.
im on cm stage 3, disc style, shade under 250wtq, holds fine, and the sos clutch is competitor of it and i feel will hold the same.
DFul4d
Jul 30, 2003 06:40 AM
