sos supercharger- any known issues?
Old Oct 3, 2012 | 10:39 AM
killerbee_vr6's Avatar
Default sos supercharger- any known issues?
as a previous KW kit owner, i want to know if there are any pulley / other issues with the sos kits. i have found nothing other than the SL issues.
Old Oct 3, 2012 | 10:49 AM
vadik_s2k's Avatar
I have Novi1200sl and it's good so far but I have slip issues with 3" pulley, can't get rid of slipping...other than that so far so good..
Old Oct 3, 2012 | 10:54 AM
LandR's Avatar
Try reichard pulleys might prevent slippage. Or get a custom crank pulley made.
I modified my SOS kit and have no problems with it.
-Sam
Old Oct 3, 2012 | 11:08 AM
vadik_s2k's Avatar
I'm looking for the RR pulley but no luck so far, shops either don't have them in stock or they don't really want to ship overseas...just posted WTB thread, maybe I'll find some..I see only 13psi now with 1200 and 3" pulley, I have 9,6:1 mahle pistons so boost will be lower than on stock CR but still...gonna super tight the belt tomorrow :-)
Are you still on SOS crank pulley, just RR pulley?
Old Oct 3, 2012 | 11:12 AM
Moddiction's Avatar
Former Sponsor
^Don't tighten it too much or you can blow the sc out.
Old Oct 3, 2012 | 11:15 AM
vadik_s2k's Avatar
I'm following "90 degree" rule but there is not much space to check with fingers, according to logs right now boost stops climbing from 6500 and stays basically the same till the redline so probably it's a belt...I've used some belt conditioners but they don't really help..
99SH's Avatar
You can get the RR pulley from http://www.lethalperformance.com
I just ordered a 3.1" from them and received it within a week.
Old Oct 3, 2012 | 11:24 AM
vadik_s2k's Avatar
They don't stock pulley for Paxton blower but the staff promised to find out about them...so should I order 6rib, right? Nobody tried 8 rib pulley?
Old Oct 3, 2012 | 12:52 PM
99SH's Avatar
Can you fit a 8-rib pulley at the crank?
My 6-rib SOS crank pulley is very close to the power-steering rack.
Old Oct 3, 2012 | 12:57 PM
i would be running the standard ap2 stage 2 pulley for 9-10 psi. i am not anticipating any belt slip.
