spark plug gapping
Old May 5, 2006 | 02:29 PM
r_duff's Avatar
Default spark plug gapping
After a few hrs reading threads about recommended spark plugs for FI, i decided to go with the NGK 7405.
I was unable to find any concrete info on gapping. Ppl seem to gap from ranges .34 - .44.
I have the CTSC on my 03 and will be running a 7psi pulley soon. Any thoughts on gaps?
Old May 5, 2006 | 02:33 PM
Tony Yeung's Avatar
i believe xviper said .040 for NA, .035 for FI
Old May 5, 2006 | 02:35 PM
Sideways's Avatar
All those gaps should work. The higher the pressures in the combustion chamber the smaller the gap need to be. At 7 lbs boost a 0.035 or 0.034 should be great. With 14 lbs boost I'm running 0.032.
If your gap is too big you will get a misfire.
Old May 5, 2006 | 03:11 PM
r_duff's Avatar
that's all!
sideways, you are super helpful, as always. i'll buy u a beer some time
Old May 5, 2006 | 08:19 PM
gomarlins3's Avatar
I have the same set up and I have mine at 35 I believe.
Old May 10, 2006 | 04:26 AM
robert112's Avatar
I would like to add to this. you want the biggest possible gap you can get without a missfire. this way you will burn the fuel properly and get the most power by fully burning the fuel for that cycle without misfiring.
its not just a matter of going a tiny gap without misfiring. be greedy and go for the largest gap you can without blowing the spark out.
Old May 10, 2006 | 09:48 AM
SIIK2NR's Avatar
Hmmm....
So by the time you figure out that your gap is too big you've already misfired on 1 or all cylinders..... No thank you.
Tuning with spark plug gap is NOT what I would suggest.
JMO.
Tim
Old May 11, 2006 | 12:38 AM
robert112's Avatar
why not?
you think a few misfires is going to cause dents in the s2k's forged pistons? s2k's have knock sensors anyway it'll automatically retard the timing.
This is coming from experience. I had a 12 second s13 and getting the right sized gap is important.
Old May 11, 2006 | 07:30 AM
Wisconsin S2k's Avatar
moving to FI
Old May 11, 2006 | 12:18 PM
9kFever's Avatar
what are the NGK 7405 series? all my research pointed me towards the 7173 copper racing plugs...
