Spark plugs ?
Old Dec 16, 2008 | 10:31 AM
MugenRioS2k's Avatar
Originally Posted by Ben-NSI,Dec 16 2008, 02:00 PM
What happens is the ignition system pushes a signal back into the e-manage causing a variety of problems and depending on the type of ignition system implemented on the car can even burn up the coils.
we are getting off topic;
Are you suggesting the diode on the triggery wire the ULT and the Coil trigger .
I dont see how a resistor plug ( resistor in the primary voltage path) can lead to a back voltage into the ULT/ECM through the trigger wire when the circuit with the resiator is isolated from the trigger in the coil.
I think that may have been a problem with previous versions of the ULT circuit board.
Lets move this line of comments to the Emanage thread.
https://www.s2ki.com/forums/index.ph...f=148&t=408667
Old Dec 16, 2008 | 10:42 AM
GDM S2K's Avatar
NGK 4091 for break in
Old Dec 17, 2008 | 12:03 AM
roi's Avatar
roi
O.K I did not mean to start a small resistor war, I just wanted to know what plug to use on the S for the high HP and boost.
Thanks
Old Dec 17, 2008 | 02:37 AM
misz's Avatar
How about BCR 8ES and BCPR 9ES, 1 and 2 steps colder. Maybe a 2.5mm modifaction of the top is needed. Have anyone tried?
Old Dec 17, 2008 | 06:09 AM
neither did I
That
Old Dec 17, 2008 | 10:01 AM
ThatPreludeGuy's Avatar
Originally Posted by Opposite_Lock,Dec 16 2008, 03:18 PM
I used non-resistor copper plugs (NGK 7173s) in my car as well, and no problems at all. Running EMS.
I ran them and started getting a flashing immobilizer light as well as it freaking out the Modifry DCI. I replaced with the NGK Iridium and it stopped, however my 7173's were at about 5500 miles and most people seem to replace them at 3k so if I was on that schedule I probably wouldnt have had any issues.
Old Dec 17, 2008 | 12:54 PM
Opposite_Lock's Avatar
Good to know. I replace my plugs at 3k as well, cause they're so cheap! If I ever get lazy, I'll see if I get similar symptoms.
Old Dec 17, 2008 | 01:31 PM
passmans2kny's Avatar
ngk 8s or 7s should be fine
Old Dec 17, 2008 | 01:49 PM
Ben-NSI's Avatar
7s are stock...
Old Dec 17, 2008 | 02:15 PM
JDMallmotorAP1's Avatar
NGK for OEM 2000
part# PFR7G-11S, Stock# 7772. Platinum tip, 14mm, 3/4" reach, 5/8" Hex. heat Rating: 7, Gap 1.1mm (.044")
NGK for 1step colder
part# R5672A-8, Stock# 7173. 14mm, 3/4" reach, 5/8" hex, heat Rating: 8
NGK for 2step colder
part# R5672A-9, Stock# 7405. 14mm, 3/4" reach, 5/8" hex, heat Rating: 9
Gap .028 to .030.
