spark plugs
Old May 29, 2012 | 04:06 AM
ravi1987's Avatar
Default spark plugs
im thinking of going the supercharger route and want to know what spark plugs u guys use. on the CT engeneering website they have Spark Plug - DENSO IRIDIUM (IK24)
listed are these any good? and do you guys have any other recomendations? thanks in advance
Old May 29, 2012 | 05:31 AM
manny-s2000's Avatar
Ngk bkr8eix is what I use..
Old May 29, 2012 | 06:00 AM
herecomesboost's Avatar
x2
Old May 29, 2012 | 06:02 AM
ravi1987's Avatar
what diffrence does it make what kind of spark plugs i use? noob question ... what if i used the OEM ones from dealer and not the Ngk bkr8eix or DENSO IRIDIUM (IK24)
Old May 29, 2012 | 06:10 AM
Well the NGK ones are 1 or 2 steps colder from memory. Depends on preference at the end of the day I suppose you only know till you try them and see what's works best with your engine. I'm not sure about gapping so I can't comment on that.
Depending on the climate, in Sydney usually it's pretty hot so I went a little colder in the heat range.
(don't know wtf happened the past 2 years weather has been sh!t!)
Old May 29, 2012 | 07:26 AM
Deception's Avatar
using too hot of a plug on an FI setup can cause detonation, on the other hand using too cold of a plug for your application will cause them to foul prematurely
A lot of people use the NGK 2668's (bkr8eix) on here , myself included. Seems to work well for the 350 - 450whp range.
Old May 29, 2012 | 07:54 AM
ravi1987's Avatar
coool i get it now im gonna go with NGK's 2668's (bkr8eix) thnx guys
Old May 29, 2012 | 08:06 AM
boostedf22c's Avatar
I use this same plug. Seems to work well in the 1000+hp range too.
Old May 29, 2012 | 08:23 AM
passmans2kny's Avatar
i use em at 800 too
Old May 29, 2012 | 09:07 AM
InductionPerformance's Avatar
They work fine. We prefer to use NGK BKR7EIX and NGK BKR8EIX.
hypforlife32
Dec 7, 2010 05:57 AM
liquid_helix136
Mar 3, 2010 08:01 AM
ash2k
Jan 12, 2009 12:26 PM
HonCBRf2
Jun 28, 2008 12:42 PM
