Spark Plugs for SC aplication
Old Apr 25, 2010 | 11:41 AM
suzukablueS2000's Avatar
Default Spark Plugs for SC aplication
i'd appreciate if you give me an idea which spark plugs work best on a supercharged S2000.
thanks,
Old Apr 25, 2010 | 11:53 AM
Kyushin's Avatar
Banned
BKR8EIX
I use them, 1 step colder and iridium.
If anyone flames you for not using the search, its down as usual and very unreliable.
Old Apr 25, 2010 | 12:00 PM
RedLineS2k10's Avatar
same thing i run in my f24c...i actually switched up for 2 runs to ngk BCPR7ES...They might be too hott of plug though.. Do a run or two on them and pull them out and if u have a purple rings on the threads there too hott of a plug. Hope this helps. DEF stick with NGK
Old Apr 25, 2010 | 12:01 PM
Kyushin's Avatar
Banned
Ya for boosted you definitely wana go colder. A hotter plug will greatly increase the chance of detonation in a FI application.
Old Apr 25, 2010 | 12:16 PM
He makes a good point. Your best bet is to start with the 8's..Make sure to gap them correctly as well. Im sure there been a post about gapping the plugs for SC applications. ur gap needs to be
0.25-0.30 If im not mistaken.
Old Apr 25, 2010 | 12:17 PM
Kyushin's Avatar
Banned
Ya, the BRK8EIX plugs come pre gapped and its been said to be a bad idea to try to gap an iridium plug because you could damage the electrode.
Old Apr 25, 2010 | 12:26 PM
Enlightened's Avatar
Also look at the Denso Ik24's
Search string below:
http://www.google.com/search?q=Denso+Ik24+...&rlz=1I7GGLL_en
Old Apr 25, 2010 | 01:41 PM
TRBOKEV's Avatar
Stay away from densos!!!!!!!! I had tons of problems with those and misfires.
BKR8EIX all the way!
Old Apr 25, 2010 | 02:06 PM
Ok I agree with this, but haven't personally ran the denso.
http://www.amazon.com/NGK-Iridium-Spark-BK...72233095&sr=1-1
Old Apr 25, 2010 | 02:18 PM
So keep the .032" pre-gap then?
