Spec Clutch Users
Old May 31, 2006 | 12:05 AM
WtbS2k's Avatar
Default Spec Clutch Users
Hey guys,
I recently got a spec stage 2+ clutch installed on my car and i am having some issues with the engagement point. Mine engages at the very top of the clutch travel and i can't figer out where the problem is. The system was flushed a few times, it didn't make any difference. I also installed a new slave cylinder today because i saw some fluid leaking out from the bleed screw area, it didn't make any difference either. Is this normal for this clutch? Where is yours at?
please help!
Old May 31, 2006 | 04:36 AM
OGPackin's Avatar
Im running the same clutch and id say mine engages around the middle point. Have you tried adjusting the clutch?
Old May 31, 2006 | 06:11 AM
koji187's Avatar
The "catch" point of the clutch is adjustable, but I would have to say that mine is around the middle/end area. Also, having the clutch at the very end is also beneficial due to the capability for having quicker shifts because the pedal has to travel less.
Old May 31, 2006 | 08:06 PM
WtbS2k's Avatar
Thanks for the replies guys. i tried to adjust it behind the pedal, The clutch travel can be made shorter, but the engagement point is still at very top. It just feels strange that the car starts moving when the clutch is almost the way out.
Old May 31, 2006 | 09:08 PM
koji187's Avatar
leave it...its good for quick shifts =)
Old Jun 1, 2006 | 06:44 AM
stphotographer's Avatar
I have a SPEC Stage 2 also and my mechanic adjusted it so it releases more toward the middle of travel.
Old Jun 1, 2006 | 08:23 AM
WtbS2k's Avatar
thanks again guys. Do you know how should it be adjusted stphotographer?
Thanks
Acethriller
Nov 21, 2014 01:28 AM
armthehomeless
Mar 31, 2012 02:47 PM
Pezza
Nov 27, 2007 10:15 PM
blacks2k
20
Mar 6, 2007 08:44 PM
ajkewler
Jan 9, 2006 11:36 AM
