Which StandAlone system
Old Aug 23, 2005 | 09:26 AM
Birdie's Avatar
Default Which StandAlone system
Price almost simliar
F con - 1500
EMS - 1200
I always want to know what kind of neat feature that EMS provide?
Alot of big power supra etc.. run the hks f con system. The reason for this is because it has self learning mode. Meaning that your engine will never run lean ever. I was wondering does the EMS provide this type of feature?
Old Aug 23, 2005 | 09:36 AM
Spoolin's Avatar
When you say self learning mode. Do you mean that it reads off a wideband O2 and adjusts itself accordingly to the correct A/F?
If so, I believe the EMS does this.
Old Aug 23, 2005 | 10:25 AM
Birdie's Avatar
yah that's what i mean. Reading the a/f off an o2 sensor that comes with EMS system and add fuel/air to make sure the ratio is at what you want it to be. WOW if this is true, i dont even know which system to get anymore. I was leaning toward the F con because of this reason. But now that i been reading up on it. EMS doesnt sound so bad either.
Old Aug 23, 2005 | 12:04 PM
Spoolin's Avatar
Don't know much about the F con but the EMS is supposed to be really good.
The only issue I had with it was that the stock water temp wouldn't work without a special controller wired into it seperately. AEM may have that resolved now though.
Old Aug 23, 2005 | 12:21 PM
Birdie's Avatar
hmm wth ? let me ask lem and them that ran the lovefab kit if there stock water temp is working fine.
So far right now. I found out that EMS have independent boost feature where u can adjust how many lbs of boost in each gear. Which i think its pertty neat. I wont even need a boost controller unless I want to boost high. EMS sound promising thanx spool for the info
Old Aug 23, 2005 | 01:25 PM
CrazyPhuD's Avatar
The F Con is usually a bad choice....why? Major lack of tuners around. The F-Con requires a very expensive tool to tune them and very few tuners around can do it properly. This means that tuning on the F-con will be generally more expensive than the AEM(harder to find a tuner and more expensive equipment)
Old Aug 23, 2005 | 02:02 PM
Spoolin's Avatar
No problem
Old Aug 23, 2005 | 03:19 PM
Slows2k's Avatar
Tech2drew was the only person I know of on S2ki using a FCON. You may want to PM him.
Old Aug 23, 2005 | 04:30 PM
Birdie's Avatar
Nope, SP Engineering has a japanese tunner that been using F con V pro for a while now. Im just doing my research to find out the difference between this two standalone system.
Old Aug 23, 2005 | 10:13 PM
New Concept's Avatar
Banned
BrainStorm performance in Culver City also tunes this ecu. its their favorite.
