The start of some fun times
Originally Posted by kane.s2k,Oct 8 2006, 10:11 AM
off topic...where have you been? I never see you post anymore.
Nice to know I'm missed.
On most cars the top of the pan is just below the centreline of the crank so tapping it is no problem. Because our car uses the ladder frame girdle (a major reason it can rev so hard) the pan is lower and shallower.
So tapping the pan is a fairly low point. I expect Vortech do it because it's easier rather than recommended. But the girdle is defintiely the better point.
All that said, I tapped my pan and haven't had an issue.
The reason you should tap the girdle and not the pan is restriction. You want zero restition on the oil flowing out of the turbo. If you have oil sitting in the line because the return line sits at a level below the oil level in the pan it will restrict the oil exiting the turbo. That being said, I too have my pan tapped and haven't had any problems. Now on my new set-up I am going into the girdle but that's for clearance issues more than anything.
