step by step turboing instructions
Hey guys,
I've been kinda looking for a thread where the step by step process for turboing your S is explained but I havent been able to find much.
im looking for information such as...
when do you need to upgrade injectors?
when do you need to upgrade rear end? fuel system? etc..
Thanks!
Thanks!
It has been discussed several times, not in one post but several different post. Injectors need to be changed based on what boost your at. It's hard to say, mine may max out at one point where someone else's doesn't. As far as the rear end, that is really up to you. There has been several s2000's with high hp numbers running the stock rear end. Granted they're not launching it. If you plan on launching the car and are boosting, consideration on a new rear end should be considered. I'm not sure on the fuel system as I have the inline pro kit and it came with a new fuel pump. An engine management system will be needed as soon as a turbos bolted on.
Gernby
Dec 7, 2010 05:52 AM
