stock clutch
Old Apr 18, 2006 | 12:02 PM
Enthralled's Avatar
Default stock clutch
I bolted my charger on at 13k miles....I now have 19k and some change and my clutch is slippin..was wondering about how long it lasted most of you with a stock clutch that went FI.
Peace
David
Old Apr 18, 2006 | 12:32 PM
John_Z's Avatar
For me about 1 yr/ 4k miles until it started to slip from 3rd to 4th.
Old Apr 18, 2006 | 02:34 PM
Slows2k's Avatar
It's all driver dependant, not milage.
Some have gotten 50K+ with a SC anf a stock clutch, Others roast the stock clutch in a week.
Old Apr 18, 2006 | 02:56 PM
xviper's Avatar
2.5 years and almost 25K miles blown, nearly 40K total. Starting to slip but still driveable. You are the one in control.
Old Apr 18, 2006 | 03:54 PM
John_Z's Avatar
I drive like a mad man
Old Apr 18, 2006 | 04:12 PM
xviper's Avatar
It's not how hard you drive. It's how you drive hard. Until you figure this one out, you'll just be burning up clutches, plain and simple.
Old Apr 18, 2006 | 04:20 PM
XclusiveAutosports's Avatar
hmmm... maybe with a SC'er you are the one in control, but with a turbo setup the stock clutch doesn't stand a chance if you put down some decent torque figures. At least this was my case. I brought my car to the dyno with 15k on the clutch and I baby the clutch, no dumps, etc, and by the 3rd pull it was slipping real bad. I would suggest to any future turbo guys to upgrade the clutch before you install everything twice like I did.
Old Apr 18, 2006 | 06:09 PM
kenyellows2k's Avatar
just curious why did you install turbo again, cant you just have the shop change your old to new clutch or once turbo is in, to install clutch it has to come off. I know engine has to drop a bit.
Old Apr 19, 2006 | 12:32 PM
OyATL's Avatar
The stock clutch held up fine when I was using the stock pulley (5.5lb). At 70K, I went with a smaller pulley (10lb.), it started slipping and I replaced it with the ACT. I'm sure the stock clutch would of held up fine if I was still on the stock pulley.
Old Apr 19, 2006 | 01:07 PM
00S2K01S4's Avatar
My 94 Prelude VTEC with 185K miles is still on the original clutch. I'm hoping after my SC install, I can get that much in my S2K.
