Stock compression and 9.75 psi
Old Oct 16, 2006 | 06:56 AM
Spoolin's Avatar
Default Stock compression and 9.75 psi
Well, I had my car tuned safely on 9.75 psi by Devin with the stock compression and it's making 397 whp and 258 lbft of tq.
Let me tell you, the difference between 332 and 397 whp is huge!
Old Oct 16, 2006 | 07:08 AM
QUICK_AG's Avatar
Nice #'s bro. congatulations!
Old Oct 16, 2006 | 07:14 AM
WindchaserS2K's Avatar
wow can a stock engine handle more than 9lbs???
Old Oct 16, 2006 | 07:23 AM
kenyellows2k's Avatar
you're in the 400hps power club. I am hitting 370 at wheel at 8.75 psi. I see you have UR cat, I will go that route too, my car is pump out too much tar its alll over my garage.
Old Oct 16, 2006 | 07:46 AM
PRS2K's Avatar
Great #'s
Old Oct 16, 2006 | 08:12 AM
m R g S r's Avatar
nice numbers!!! when does it start to spool with the 60-1? and when do you see full boost?
and why stock compression if you are running a built motor? you shoulda lowered it while you were at it.....
Old Oct 16, 2006 | 08:44 AM
XclusiveAutosports's Avatar
That is awesome! I was suppose to turn up the boost to 9lbs last week, but haven't been able to since my car has a nasty rattle coming from the head/manifold. Did you change your map sensor?
Old Oct 16, 2006 | 08:48 AM
Erick S's Avatar
Whoa, beautiful numbers! Enjoy!
Erick
Old Oct 16, 2006 | 10:40 AM
passmans2kny's Avatar
congrats, watch everyone running 7 psi now turn it up to 9
Old Oct 16, 2006 | 10:56 AM
Spoolin's Avatar
It's on the stock MAP sensor right now and that's why Devin limited it to 9.75 psi. We could have safely run more but I didn't have the time to change the sensor. The stock MAP sensor will go up to 10.94 but doesn't like it very well and starts to break up.
This spring I will be putting the Inline 3mm HG on and going for around 500 whp and limiting it there because I think anything more is just a waste in this car.
