Stock compression and E85?
Old Jan 18, 2010 | 11:32 AM
B5254T4's Avatar
Default Stock compression and E85?
I´m thinking about a cheap stock engine turbo build for a start, is it even worth the hassle without thicker head gasket?
And also, I want to use E85 to keep the detonations away. What kind of numbers could I expect?
Of course pump, injectors and other parts taken care of.
Old Jan 18, 2010 | 11:49 AM
D1sclaimer's Avatar
If you're going to push the motor on E85, it would be wise to get a dual fuel pump setup IMO.
For power with E85, I would like to know the answer too.
Old Jan 18, 2010 | 12:02 PM
B5254T4's Avatar
If we compare E85 to VP race fuel on Volvo engines we see pretty much the same numbers. Around 100 hp gain on a 500hp engine.
Maybe hard to compare 8,5:1 and 11:1 comp ratio but a huge gain in numbers.
What´s the normal hp limit on stock compression?
Old Jan 18, 2010 | 01:10 PM
Spoolin's Avatar
Stock compression on the F20c engine has been pushed to 700+ whp on Q16. E85 is very comparable to C16, so I would assume on the stock CR, you could push it to around 650 whp if you wanted to.
Old Jan 18, 2010 | 01:20 PM
nsx_bob's Avatar
run meth and e85
Old Jan 18, 2010 | 07:42 PM
B5254T4's Avatar
That´s a lot of hp´s! I thought you would say 400whp max.
Also, is Greddy E-Manage Ultimate good enough for a turbo build, anyone tried above 400hp?
Got to be the "bang for the buck solution" for the AP1 huh? Nice price and pnp harness.
Thanks guys!
Old Jan 18, 2010 | 07:45 PM
wadzii's Avatar
Banned
e85 around here isnt too good. there are only a couple of pumps and the car basically needs a re-tune if the fuel comes from a different pump.
i'd never use it for a big power turbo car. too many variables in the supply
Old Jan 18, 2010 | 07:58 PM
Deception's Avatar
is it like that everywhere? I was thinking of it as a future upgrade, but not so sure now.
Old Jan 18, 2010 | 08:05 PM
deathsled's Avatar
There's only one that I know of in the whole RDU area, luckily it's right by where I work, so I've considered converting one of my cars like my vr4 or stealth to e85 just for kicks.
Old Jan 18, 2010 | 08:21 PM
crispeed's Avatar
I have made upwards of 920whp on a 2.0l 4cyl. using E85. I've also ran upwards of 50 psi on a 11.1 motor.
From my experience E85 always made more power with greater spool up vs Q16.
