Stock Sleeves
Old Apr 17, 2008 | 08:14 AM
kutsujula's Avatar
Default Stock Sleeves
I'm not looking to break any land speed record's at all with this car, I just want it reliable. Has anyone just put pistons/rod's in the motor and left the stock sleeves in there? I wanna make 450whp all day safely. Would some pauter rod's and some cp 9.0:1 comp piston's and oem honda bearing's do the trick? Anyone else running just piston's and rod's?
Old Apr 17, 2008 | 08:19 AM
btstone84's Avatar
i put more than that down all day long and i have changed nothing
Old Apr 17, 2008 | 08:22 AM
Soul Coughing's Avatar
due to the FRM sleeves, the choice of pistons is rather limited! I'm not sure what you can buy that will be compatible with the stock sleeves!
Old Apr 17, 2008 | 08:23 AM
kutsujula's Avatar
That's another thing I was wondering, it's like the H22.
Old Apr 17, 2008 | 09:23 AM
USMCAP1's Avatar
All i have is a 3mm head gasket with an upgraded InlinePro kit. i put down 512whp. I am as daily driven as you can get, its my only car. i have put almost 5000 miles on it since Feb 29 and thats with 2 weeks of it sitting due to me having to go somewhere. Shes still good!
Old Apr 17, 2008 | 09:54 AM
passmans2kny's Avatar
u guys get me so excited seeing people say they run 500 hp all day long, i cant wait til june
Old Apr 17, 2008 | 10:51 AM
jwa4378's Avatar
The piston I think is called a "slipper" style piston... does not fit as tightly against the cylinder walls, I think... I have heard a bunch of lower comp pistons will chew up the walls, as they are not meant to "slip" like OEM pistons...
This is all 2nd hand research... Its all in the tune. You can put 500 down on stock everything (see Mase's work). He claims the only the 600+wrhp pull was pushing the limits of the fuel system... I think the pull that was in the 470's could be replicated daily.... but again, could be wrong...
John
Old Apr 17, 2008 | 12:03 PM
USMCAP1's Avatar
^^^ 600+ on pump??
Old Apr 17, 2008 | 05:27 PM
one_slows2k's Avatar
If you're not looking into breaking any records, you don't need to change anything.
**** correction, just read the part about you wanting 450whp.. well, add a headgasket. lol (originally thought u were going for 300 or so since you weren't lookin to set speed records )
Old Apr 17, 2008 | 06:40 PM
Spec_Ops2087's Avatar
Originally Posted by USMCAP1,Apr 17 2008, 03:03 PM
^^^ 600+ on pump??
Pretty sure it was race gas
