Storing a Turbo S
Old Mar 29, 2010 | 04:51 AM
buzz944's Avatar
Default Storing a Turbo S
hey guys im installing the turbo kit this week, and im traveling to US (for studying) on the end of May,
is there any harm in keeping a turbo S2000 in the garage for 10 Month (more or less)??
my brother will start the car every once in a while,
any tips?
thank you,
Ali
Old Mar 29, 2010 | 08:54 AM
Spec_Ops2087's Avatar
Don't start it every once in a while
Fill the gas tank up
Either connect a trickle charge battery charger or disconnect the battery entirely
Change the oil before you first start it after the 10 months
Old Mar 29, 2010 | 09:54 AM
siadam's Avatar
I only let mine sit for 2-4 months over the winter...
All I do is pull the battery and put a cover on it.
If you are in severe climate, I'd make sure my coolant was properly mixed to ensure you don't get a cracked block, and I try to time my oil changes so I get the most out of it before I put new in for the spring.
Maybe put a piece of carpet under each tire so it doesn't sit on the concrete.
Other than that...don't sweat it.
If it's going to be a long time, I would drain the gas tank, and then put fresh in, whats in the lines will make it stutter/pop for a few when you start it but burn up rather fast.
B/c if you have a full tank, I wouldn't feel comfortable running all that through...would take way to long.
Old Mar 29, 2010 | 10:01 AM
stitos2k's Avatar
If you live next to a field or have mice you may want to wrap your air filter with steel wool to keep them from chewing on it. Those things will eat anything.
Old Mar 29, 2010 | 10:54 AM
spectacle's Avatar
Why not?
Old Mar 29, 2010 | 11:05 AM
Vi3tBoy's Avatar
The reason for starting it every once in a long while is it's really hard on the motor(Dry). Might as well just wait all the way till spring or whenever you are going to drive it again so it's only hard on the motor to start up one time.
Old Mar 29, 2010 | 11:15 AM
spectacle's Avatar
Umm, no its not.
I'm not speaking out of my ass if you look at my sig you can see I used to be in the military. Have stored plenty of cars over the years and had friends start them every month or so. Its not hard on the motor. Dunno where you're getting that from.
Old Mar 29, 2010 | 11:49 AM
Quivers's Avatar
Banned
Originally Posted by spectacle,Mar 29 2010, 01:15 PM
Umm, no its not.
ok buddy, if you dont want the advice dont take it but what benefit do you see from starting it?
Old Mar 29, 2010 | 01:07 PM
spectacle's Avatar
Keeping a charge on the battery
Old Mar 29, 2010 | 01:22 PM
PsykotiK's Avatar
why would it be hard on the motor.. its like saying that every time you start the car.. youre taking life away from the car
