Supercharged & AEM v1 massive rich spot partial throttle
Old Jun 5, 2015 | 03:14 PM
amdaman's Avatar
Default Supercharged & AEM v1 massive rich spot partial throttle
Hi,
My car has recently been tuned and it's pretty good. I've sent it back recently to get a few niggles sorted such as the cold start and a rich spot. The tuner has sorted the cold start issue but is having a few problems with the rich spot. It's occurring at 6000-6200 rpm and it's only under partial throttle. The tuner has pulled a lot of fuel from the area but it's still running rich which is causing the motor to bog down.
Thought I'd ask on here to see if it's common or something that is linked to the AEM. My setup is:
AEM 1052u
AEM wideband wired in
Novi 1000
2.8" pulley
3bar map sensor
Decat
Fmic
Bosch recirc
14.5 PSI peak boost
7.4psi @ 6000rpm
Vtec 5700rpm
Any help appreciated,
Cheers
Old Jun 5, 2015 | 07:09 PM
tom153's Avatar
Are you running a boost comp map? Wonder where he pulled the fuel from, that point on the map, or some trim table? Running rich in a certain spot is certainly not normal, especially under boost. Post up your cal if you can.
Old Jun 5, 2015 | 07:49 PM
amdaman's Avatar
Think he used a base supercharger map and is using the trim table. During WOT it's absolutely fine though, nothing abnormal is going on, it's just partial throttle, almost like it's expecting the boost and throwing the fuel in but obviously most of it is flowing out of the BOV.
It's still in the shop but will post it up once I get it.
Old Jun 5, 2015 | 08:28 PM
tom153's Avatar
Check to see if there's a large VTEC trim since the two points are kind of close to each other. Also, how rich does it actually get?
Old Jun 6, 2015 | 02:07 AM
amdaman's Avatar
I'll take a look as soon as I get the map. I'm not sure how rich it goes, it was showing 10 on my afr Guage which is the lowest it will display! I will do some data logging when I get it back too.
Old Jun 8, 2015 | 03:23 AM
amdaman's Avatar
here's a link to the .cal file
https://www.dropbox.com/s/0dh0ncx4v7...V1.19.cal?dl=0
let me know what you think. It also seems to run really rich on <5% throttle and makes the car judder a bit.
Can you see any issues?
Thanks
Old Jun 9, 2015 | 08:24 PM
tom153's Avatar
So your map is set up to dump a lot of fuel in that area, I'm assuming he did that for vtec, however, it adds a lot even at light loads. Also he turned off your wideband feedback for some reason, so the car runs strictly off the map.
Send me your email and I can send you an updated cal with a few changes. You'd have to provide some logs too (hit F6 on the "tuning" tab).
Old Jun 9, 2015 | 08:25 PM
tom153's Avatar
Also, what injectors are you running?
Old Jun 9, 2015 | 08:36 PM
amdaman's Avatar
Cheers Tom,
What should be happening in that area? Should there be a VTEC trim?
What does the wideband feedback do with regards to fuelling for the map? I think he mentioned my wideband was slighly off his wideband when he was tuning (the display on the guage) I've read that the wideband signal wired into the EMS can be different for the guage though. Do i have to calibrate anything?
Do you want a log with the current map or with your map?
Any idea why i get juddering on very light throttle (like <5%) the AFR goes nuts when this happens, like back and forth rich to lean.
I have ID1000's
Apologies for the questions and I really appreciate the help.
Old Jun 9, 2015 | 09:59 PM
amdaman's Avatar
PS amitw1985@gmail.com
Fuel Log
https://www.dropbox.com/s/4htki13y93...fuel1.stf?dl=0
Fuel Log1
https://www.dropbox.com/s/bra45si6sx...fuel2.stf?dl=0
Ignition Log
https://www.dropbox.com/s/pfn04u9nwd...tion1.stf?dl=0
I tried to capture the low throttle juddering and the 6000-6200 rich area
