Supercharger upgrade options?
Old Feb 24, 2012 | 10:23 AM
jonnysc14's Avatar
Thanks for all the info I learned a lot of valuable info.
so would an aem 3.5 map sensor be good to run the 3.2 pulley, also would the 1000cc injectors be good enough to run this setup or should I get higher or lower injectors?
Old Feb 24, 2012 | 10:40 AM
s2000Junky's Avatar
No problem, glad I could help.
3.5 map and ID1000 injectors will be wise choices for your set up to full capacity, should you ever want to get there, and will suit you perfectly fine for anything less for the time being.
Old Feb 24, 2012 | 10:45 AM
jonnysc14's Avatar
ok thanks I will be piecing all this together before I install the kit that way it all gets done at the same time
Now i gotta see what clutch suits these uprades
Old Feb 25, 2012 | 10:09 AM
ATOice's Avatar
My 2nd boost option was using a 3.5 inch pulley and I hit 360 hp. I topped out where I am now running a 3.0 inch pulley. I want to move up to 1200 blower eventually to crack 400 (Hoped 3.0 inch would have done it, but dyno'ed in 110 temps in FL in the summer)...but I'm happy where I am now.
Old Feb 25, 2012 | 05:21 PM
Sideways's Avatar
I would think a little cam timing change would allow you to see 400 hp.
Old Feb 25, 2012 | 08:36 PM
jonnysc14's Avatar
So what is your current set up? In how you achieved those numbers
Old Feb 29, 2012 | 08:37 PM
MMM1787's Avatar
I have a comptech kit with the stock pulley and aftermarket after cooler I want to move up to 7 or 9 psi I don't have any engine management or anything like that . I basically looking for what I would need to achieve this. What kind of electronics or injectors stuff like that.
Old Feb 29, 2012 | 08:46 PM
DFWs2k's Avatar
you may want to go with a map sensor that is plug and play
Old Feb 29, 2012 | 09:31 PM
MMM1787's Avatar
[quote name='DFWs2k' timestamp='1330580807' post='21465071']
So I wouldn't need a stand alone or injectors. I bought the car with the kit already on it m not sure what comes in the kit like injector sizes. I know the car hasn't been tuned. Can you get it tuned with just a map sensor. Sorry I'm new to the s2k world and tuning
Old Feb 29, 2012 | 09:42 PM
Moddiction's Avatar
Former Sponsor
To get the car tuned you need a tuning sollution. Aka stand alon ecue or a piggy back tuner as well as larger injectors.
