Switched from Kpro to AEM Infinity - new Dyno #'s
Old Jul 27, 2017 | 12:31 AM
jzz30's Avatar
505tq?! Wow
Old Jul 27, 2017 | 07:26 AM
circuitclub's Avatar
Active Streak: 30 Days
Great to hear that it's working out for you man. I need a ride in your car some time.
Quin
Old Jul 27, 2017 | 12:27 PM
Sobe_Death's Avatar
Nice! I was thinking about getting an Infinity for mine. Which shop did you have do the tune?
Old Jul 27, 2017 | 10:55 PM
S2K-F8's Avatar
My good buddy Dan is a tuner, so he has been helping me with the install and all the tuning.
Old Jul 28, 2017 | 08:56 AM
S2K-F8's Avatar
Quin
For sure Quin!!!
Old Aug 19, 2017 | 10:44 AM
S2K-F8's Avatar
Originally Posted by Spoolin
630 whp on 14.5 psi? Hmmmmmmmmmm
So after talking with my tuner about our last dyno session, we both thought my #'s were a bit high for the boost we were seeing. We thought my old SOS Map was reading incorrectly, so I picked up a new Omni 4 bar and we went back on the dyno.
Old Map sensor def reading incorrectly! New dyno sheet with overlay from last session. We are now targeting 16psi (it's spiking to ~19psi then dropping back down). We lost a bit of HP and quite a bit of TQ, but gained a little spool up (possibly due to cooler temps this time?)
So we ended up at 617/478
I just ordered the SOS pulse converter so we can setup traction control and boost by gear
Scott-
Old Aug 19, 2017 | 02:21 PM
AP1Chief's Avatar
i hope you realize your more like mid 400s..... numbers don't add up at first glance, 14-16 lbs make 600+ did not jive lol.... Now I see whats going on... Corrected crap..
Old Aug 19, 2017 | 02:27 PM
AP1Chief's Avatar
497 actually....
Old Aug 20, 2017 | 10:42 AM
snitm's Avatar
Are you using the AEM Infinity PnP harness?
Good luck getting the SOS pulse converter to work reliably. I tried 2 different pulse converters and neither worked. The signal was very unreliable/jittery (triggering false positives for wheel slip) and soldering the very fine gauged wires of the pulse converter is an extreme exercise in patience.
Ended up just connecting the front left ABS signals direct to my AEM Infinity. Works reliably for my needs (2.4L NA doesn't see much wheel slip anyway).
Old Aug 20, 2017 | 10:55 AM
S2K-F8's Avatar
Damn...that's not good!
Yes I'm using the Infinity PnP wiring harness
