Switching from log to a ramhorn!
Old Jul 26, 2011 | 11:16 PM
alanpikku's Avatar
Default Switching from log to a ramhorn!
Hey guys, I'm currently running an Ultimate racing turbo kit. I made 375 hp on 91 at 11 psi. Made 523 hp on e85 at 20psi. Anyways, I purchased a Ramhorn Forged performance manifold to replace my log manifold. It's getting installed this Wednesday. I was wondering if it's safe to drive around with the new manifold? I'm asking because it will probably be another 2 weeks before I can get it retuned, thanks. Btw, I will post the before and after dyno graphs to see how much power the ramhorn helps me pick. The only other part I have installed on my car is a SOS throttle body since the last tune.
Old Jul 27, 2011 | 03:14 AM
Deception's Avatar
dont drive it until you get retuned
Old Jul 27, 2011 | 03:45 AM
rikhemi's Avatar
I would think you can drive it but dont do any moderate to hard pulls until you get retuned.
Old Jul 27, 2011 | 03:52 AM
o'malley_808's Avatar
The temptation is so strong that you usually do it anyways lol even if it isn't full throttle
Old Jul 27, 2011 | 06:29 AM
tmcerce's Avatar
is this a top mount or a bottom mount?
Old Jul 27, 2011 | 06:33 AM
s2knoob89's Avatar
Bottom mount.
Old Jul 27, 2011 | 06:50 AM
camuman's Avatar
Go into ur map and set a boost cut at 1psi. Then no prob driving around on it.
Old Jul 27, 2011 | 06:59 AM
Thunder-rush's Avatar
You Wuzzies...! hehehe.! You can drive the car but try to not boost over 5psi. You already have pulled timing and gas for 11psi as mentioned by you in the post so with the new manifold it might run a bit leaner as of the added flow.
Old Jul 27, 2011 | 07:01 AM
Get it tuned!
Old Jul 27, 2011 | 07:25 AM
alanpikku's Avatar
Thanks guys, I will not go into boost now. I never knew a manifold swap effected these cars so much! I will def update results.
