It was tct.. :)
Old Jul 8, 2010 | 03:53 PM
ZSAK's Avatar
Default It was tct.. :)
I am wondering if rod knock comes and goes. Meaning if the car is cold its ticking loud but when warmed up the noise subsidize. Also can it start when your car is slowing down to a stop? I noticed my car making a loud ticking noise when I pulled into the store, however it would come and go. I think it maybe tct, but it was pretty loud. I am currently getting my tct fixed and hopefully thats the trick.
I did check my plugs and they looked good except for one which was a bit blacker than the rest. The one thing that was off was that the plugs were pretty loose. I won't know for sure if the tct will fix it but I wanted just to know what you all thought it can be.
My car was low .5 qt of oil the other day but I filled it up. The car seems to idle fine too.
Could be engine rebuild time which could be fun
thanks for the help
Old Jul 8, 2010 | 04:15 PM
TRBOKEV's Avatar
That is a bad TCT IMO. Mine was exactly the same when I had TCT problems two years ago. It was really noticable at lower RPM and when coming to a stop etc..It would also come and go often..
Pull the TCT, sandblast the tensioner, clean, repin and re install. If you use Mobil 1 oil I highly recommend you switch to at least the European blend 0W40 or some other oil like redline etc which contains ZDDP.
Old Jul 8, 2010 | 05:53 PM
ZSAK's Avatar
i sure hope its the tct. I havn't used mobile one in a while, lately I have just been using castoral gtx. I may try the 0w40 hopefully its good for the engine
Old Jul 10, 2010 | 06:31 PM
ZSAK's Avatar
well kev you were right it was tct. It started ticking a little when I first started car but then it went away and has not come back yet. I do hear a little ticking but I think that maybe the valves. Now I have to figure out why I am getting some smoke out of my exhaust seems like we our problems coincides with each others lol
Old Jul 10, 2010 | 07:02 PM
TRBOKEV's Avatar
How much smoke are we talking about? Your on a ball bearing 5965B correct?
Old Jul 11, 2010 | 05:40 AM
ZSAK's Avatar
Yeah its ball bearing, The smoke is just enough where I can see it, but it dissipates pretty quickly. So not too bad.
Old Jul 11, 2010 | 07:53 AM
camuman's Avatar
so i asked this in another thread and didnt get an answer, will a ticking tct ultimately cause any damage? or is it just an annoying ticking sound and thats it?
Old Jul 11, 2010 | 01:10 PM
ZSAK's Avatar
i am sure it can, not 100% sure. The way my car sounded it seemed like it was damaged. I am sure if the timing chain gets messed up it can cause some problems
Old Jul 11, 2010 | 06:38 PM
AusS2000's Avatar
I don't believe there is a report of an engine failure caused by a bad TCT as of yet (could be wrong though).
06s2kid
Apr 13, 2016 04:57 PM
Suvs
Aug 24, 2012 04:44 AM
Assass1n
Apr 10, 2008 05:27 PM
dmw16
Jan 28, 2008 08:36 PM
vtidan
Apr 28, 2006 05:45 AM
