Is there a direct replacement header for Inline log?
Old Jan 22, 2014 | 03:29 AM
cujet's Avatar
Default Is there a direct replacement header for Inline log?
My 04 has the Inline Pro log manifold. While I could fabricate a 321 stainless header as I've done in the past, I'd like to consider purchasing a "drop in replacement". Are there any such animals? Or are the other setups different enough that my turbo would end up in a different location or angle?
Thanks!
Old Jan 22, 2014 | 04:58 AM
bruthaboost's Avatar
I've been here for a while and have yet to see one. The only cast manifold replacement I'm aware of is the greddy/Pfab swap.
BTW, if you haven't already, it wouldn't hurt to check your passenger side engine mount.
Old Jan 22, 2014 | 05:52 AM
passmans2kny's Avatar
full race ramhorn will have the turbo in a very similar location
Old Jan 22, 2014 | 06:44 AM
KaNgArOo's Avatar
There is a guy that works at synapes performance that made a drop in replacement tubular manifold for the inlinepro log. I should have bought it when he was selling it. Now he is just selling the whole car.
Old Jan 22, 2014 | 11:36 AM
cujet's Avatar
Thanks for the replies.
I'm not needing more power. But, I am in need of more response. My Inline Pro setup is the most unresponsive turbo setup I've ever driven. The turbo header can help build boost faster. I guess if I decide I need one, I'll build it myself.
Old Jan 22, 2014 | 12:59 PM
riceball777's Avatar
The log manifold responds and spools much faster than a tubular manifold. The log manifold also makes a lot less power
check out my results of the log vs tubular spool time
https://www.s2ki.com/s2000/topic/100...#entry22271490
my signature has results of how much more power tubular manifolds make over logs
Old Jan 22, 2014 | 04:33 PM
cujet's Avatar
I agree that a log manifold and it's tiny volume will provide more responsive pulses to the turbine, thereby spinning it up faster at low rpm and no boost conditions. But, under high boost conditions, such as at high RPM, the log manifold suffers mightily. We did plenty of tuning on turbo engines that prove the viability of well designed tubular headers. High RPM throttle response is better with a short, equal length, tubular header without sharp bends or excessive volume and a smooth transition in the collector. There is a reason road race engines use tubular, equal length headers.
cujet's Avatar
Oops. Double tap.
cujet
Jan 11, 2015 05:30 AM
Prokaw875
Dec 12, 2012 03:08 PM
turbosix
Oct 30, 2008 03:21 PM
Hobbyholic
May 21, 2003 05:03 AM
