Is there a DIY on a custom dual pump hanger
http://www.facebook.com/media/set/?s...5&l=a1da8a7ff8
I found this not a s2 but a idea.
Sent from my PC36100 using Tapatalk 2
If ur using 2 pumps u cant just wire it into 1...gonna need 2 relays to make it work correctly..u would be spliting the signal wire that turns the pump on into 2 which turns on both relay then would send both pumps 2 separate power
You can use one relay to run both pumps at the same time. There is a thread somewhere on this site. When I did this, I used this 75 amp relay
http://www.summitracing.com/parts/DED-BAR
However, the fuel pressure was too high at idle (at the time I had the stock FPR) with stock hard lines. So I decided to to run 2 relays and had EMS activate the second relay to turn on the second pump at X psi.
