Those with InLine Pro Diff Kit
Old Jun 10, 2009 | 08:24 AM
DER MotorSports's Avatar
Default Those with InLine Pro Diff Kit
Been losing my mind finding the fill plug but finally found it; it's located on driver side of the diff. Now the issue is it is blocked from access by the InLine Pro mount adaptor. There are 2 bolts a lower and upper holding a hanger adaptor in place, lower is easily enough removed but upper is blocked from access by the rear subframe's diff mount. Thought I might be able to swing it out so as to get to the plug but no doing. Anybody with experience know a solution? What's the official methodology? Certainly people with this kit have been changing their diff fluid, no?
Old Jun 10, 2009 | 08:53 AM
Under_Pressure's Avatar
Can u post pics of the issue?
Old Jun 10, 2009 | 12:11 PM
killabee's Avatar
If you are standing behind the car Its under the bracket that holds the diff up on the left side of the diff.
Old Jun 10, 2009 | 12:14 PM
2big4aS2000's Avatar
you change it before install, if you want to change it after install, you will have to take it apart to get to it.
Old Jun 10, 2009 | 01:28 PM
Spec_Ops2087's Avatar
fluid is good for ~100k miles
Old Jun 10, 2009 | 11:15 PM
neeman77's Avatar
Agreed, the fluid should last a very long time. Change it before it goes in or you will have to take out the whole assembly.
On a seperate note, does anyone with the inline pro diff kit still get the axle "pop" from the spindle nut? I do and I am not sure why.
Old Jun 12, 2009 | 06:23 AM
Axle pop?? Getting a constant scraping with every revolution of axle on pax side and constantly having to retorque nut. Have changed the bearing twice now. Any ideas?
Old Jun 12, 2009 | 06:27 AM
Anybody know the capacity of the system? - Perhaps it can be flushed and filled with vehicle on an angle?? What's in there originally & what's recommended? One of the things we have always done as a matter of course is change out to RedLine diff and Tranny fluids in all the cars we prep for track/road racing and it has made huge differences even on new BMWs and Porsches. This is TT 300ZX diff, correct?
Old Jun 12, 2009 | 07:38 AM
stitos2k's Avatar
r32 diff
Old Jun 12, 2009 | 07:47 AM
neeman77's Avatar
It is the non twin-turbo (NA) 300zx differential. R200 or r32 diff. Your bearing may be turning in the hub that is why you are getting the sound.
