Time for oil to "dirty"
Old Dec 3, 2006 | 12:20 PM
kleecker's Avatar
Thumbs up Time for oil to "dirty"
Noticed that it takes quite a bit less time for my oil to turn dark since going FI, compared to prior FI...... I HAVE been running the car quite hard since FI, but was revving the snot out of it prior to FI. 11K miles on an '03.
Also, what should I expect for (good) compression test readings with the 3mm (approx 9:1 CR) head gasket?
thanks,
Mark
Old Dec 4, 2006 | 07:03 AM
m R g S r's Avatar
more blowby?
Old Dec 7, 2006 | 02:54 AM
kleecker's Avatar
So, nobody else noticed the change in rate at which the oil darkens, after adding and running their turbo setup? And nobody has done a compression test on their motor after install of the 3mm gasket???
Old Dec 7, 2006 | 03:22 AM
kenyellows2k's Avatar
yes its true my motor oil got dark quicker. I have a solution for that I installed a catch can so dirty gunk doesnt get into the engine. It seems to do it and it's collecting some dark stuff, definately more than what NA would produce.
Old Dec 7, 2006 | 08:43 AM
news2kroller's Avatar
i will be doing my first oil analysis post F.I in the next few weeks, should be interesting to see the difference. get an oil analysis to chart your engine as you go on, even once a year might tell you something.
CHRIS
Old Dec 7, 2006 | 12:39 PM
CourageOO7's Avatar
Chris,
Please post the results because I have noticed my oil gets dark very quickly as well. If a catch can would help this then I'm going to go that route. Everyone experiencing this problem is using a high grade synthetic, right?
Jorge
Old Dec 7, 2006 | 02:02 PM
jbotstein1's Avatar
I get dark oil really quick. I use Redline 10W30
Old Dec 7, 2006 | 02:17 PM
John_Z's Avatar
I run Amsoil now and it turns dark about as fast as Mobil 1 did.
Old Dec 7, 2006 | 02:33 PM
ATOice's Avatar
Since going FI, I havedriven about 1000 miles, and it was black as if I had driven it for 3-4K.
Old Dec 7, 2006 | 02:37 PM
XclusiveAutosports's Avatar
I use Mobil1 and I have also noticed that it turns black pretty quickly since I have gone FI. I change my oil at 3k miles max and its black. I don't really run my car very hard either for the most part.
