Tracking Car in Spring...
Old Dec 11, 2007 | 11:50 AM
Soul Coughing's Avatar
Thumbs up Tracking Car in Spring...
Hey Guys,
I am looking to do some tracking this coming spring. I would like to do some track days, nothing big at the beginning due to my lack of skill, but longer runs than an average AutoX, but not a 40 minute run etc...
Skill aside, I am looking to get my car reliable for 5-10 minute WOT type driving. I am not looking to be that much faster than other S2K's, at least on the straight-aways!
I was thinking of throwing in my smaller pound spring and running 4-6 pounds? Reliability is key here, and i guess i was wondering if there were any track gurus out there that had raced or helped run a turbo car!
I have a 3mm headgasket, so 4-6 pounds should be around 200-240whp. I know when i raced a AP2, i was slowly pulling on one at 4 pounds.
Again, i am looking for reliability, so i was thinking of oil temp, pressure guages, I already have a Serial gauge for air temp and coolant etc...
Thanks!
Old Dec 11, 2007 | 03:14 PM
Spec_Ops2087's Avatar
I think 6psi is more around 300rwhp, surely not 200rwhp.
Either way, yes lower the boost a little bit so your engine isn't feeling the full brunt of the turbo the whole time.
Also you might want to consider a larger radiator / oil cooler as thats the real problem with tracking a turbo'd car.
Old Dec 11, 2007 | 05:02 PM
smirfs2k05's Avatar
Invest in a oil pressure gauge and egt gauge, I agree with spec ops an oil cooler will help out quite a bit.
Old Dec 11, 2007 | 05:48 PM
RacerXI's Avatar
Agreed on both of the above. You might also talk with a reputable tuner. You might want to richen your fuel mixture up just a bit to keep the inner temps cooler. The longer you run the more things heat up and heat is the enemy.
Old Dec 11, 2007 | 09:27 PM
smirfs2k05's Avatar
Also maybe mix in some race gas to help things out ..
Old Dec 12, 2007 | 10:28 AM
spec.. i am running a 3mm headgasket, so i doubt my car is making 300whp at 4-6 psi. At least with my setup that is!
So i will look into an oil cooler, oil pressure and oil temp gauges!
Getting some 100 octane to mix in might be a good idea as well! Ill send a message over to my tuner to see about richening up the mixture as well.
Old Dec 12, 2007 | 01:39 PM
yeah but I highly doubt a headgasket drops horsepower by 100 that'd be pretty crazy!
Old Dec 12, 2007 | 06:52 PM
ShMooveS2k's Avatar
i was interested in trackin my car some as well i also have 3mm HG installed but if i keep my boost at 12-13psi would that be too high? even with a richer more conservative tune? i know about the upgrading radiator will stock fans suffice and for the oil cooler any DIYs around how to install it?
Old Dec 12, 2007 | 09:23 PM
as long as the tune is good psi should be fine as far as the engine goes.
Stock fans don't fit with aftermarket radiators last I checked so you'll need new fans I think. Most oil coolers are passive so no fans needed, just speed!
Old Dec 12, 2007 | 09:30 PM
leo520's Avatar
fully engine build lolzz, and change ur turbo to gt30r BB so that way u gonna have better mid range and the power kicks in much more earlier then gt35r.
then u don't really have to worring about exiting the cornering.
GL
