Trans problem
Old Mar 19, 2012 | 03:00 PM
jdrsxtypes's Avatar
Default Trans problem
I recently had a comp. stage 5 put in my s2000. Now I am having problems getting my car to go in to any gear when ever I go above 7,000 rpm. It will only go into gear once it drops down below 7,000 rpm. The car will shift just fine when you are casualty shifting. I have tried adjusting the rod every which way to help but it has done nothing. The weird thing is when I was on the stock clutch it would go into gear at red line like butter but normal shifting was real notchy. Any input would help
Old Mar 20, 2012 | 04:30 AM
jpetch05's Avatar
Mine was doing similar things until I upgraded my master cylinder. Not saying that's the for sure problem though
Old Mar 20, 2012 | 05:56 AM
jdrsxtypes's Avatar
What master cylinder did you use.
Old Mar 20, 2012 | 06:07 AM
jpetch05's Avatar
Omni - but everyone hates these due to a defect In alot of them that we're not fully disengaging the clutch.
Old Mar 20, 2012 | 09:16 AM
Leviisbigred's Avatar
try bleeding it agin
Old Mar 20, 2012 | 10:27 PM
jjjimene's Avatar
I had a similar problem but it was at 6k and it was a CC stage 4, the problem was the calibration, i decided that it was overkill for my setup anyways and change to the stock disc and kept the pressure plate, re-calibrated at another shop and it worked well, no problems since
Old Mar 21, 2012 | 03:41 AM
miguel329's Avatar
omni quick cluth master? i pick one up sept havent had any issue hope i dont lol
jpetch05
Oct 7, 2013 03:59 AM
macdaddies911
Feb 21, 2012 03:56 PM
ntzz
Mar 8, 2010 10:24 AM
raymo19
Oct 11, 2006 12:15 AM
RS2000
May 9, 2001 09:16 PM
