Tune?
Old Jun 23, 2008 | 01:42 PM
Rollinx25's Avatar
Default Tune?
Ok, Well I'm getting ready to purchase my turbo system for the S.
I'm curious on what you guys think on which software I should get. I'm considering the Hondata S300 or the AEM UEGO.
Which one do you think is better and why?
Thanks for your input.
Old Jun 23, 2008 | 01:55 PM
ZSAK's Avatar
what do you mean? What ecu will you be using? Aem ems, Greddy emanage ult., Kpro Etc. I think the hondata s300 is just a reflash if i am not mistaken and not for an s2k ecu either. The aem uego is a wideband controller that measures your air/fuel.
Old Jun 23, 2008 | 01:58 PM
Rollinx25's Avatar
I'm trying to figure out what ECU I need or should use. I'm getting the INLINE Pro Kit with all the options. Just haven't figured out what ECU I want.
Old Jun 23, 2008 | 02:13 PM
TRBOKEV's Avatar
Get whatever Inline tells you to get then.
The most common is the 0152 or 1052U AEM Ems units.
Old Jun 23, 2008 | 02:15 PM
Rollinx25's Avatar
Thanks! I'm installing the ACT HS1-HDG4 Clutch which should hold up to the power that this kit puts out.
Old Jun 23, 2008 | 02:37 PM
ZSAK's Avatar
i just installed an inline kit and i am using the aem 1052 ecu. So far I like it. Car runs fine and feels stock. Plus you can get a good deal on it from gruppe s
Old Jun 23, 2008 | 02:47 PM
Rollinx25's Avatar
What kind of numbers are you getting out of the car?
Old Jun 23, 2008 | 03:43 PM
ZSAK's Avatar
i have the 5965 bb turbo running on 8lbs of boost on stock headgasket and exhaust, I did put in a 70mm test pipe, and made 321whp and 200lb tq. It is also tuned very conservatively as well. I am hoping with a 3" or 70mm exhaust I can retune it to around 340whp.
Old Jun 23, 2008 | 04:05 PM
Rollinx25's Avatar
Sweet!
Old Jun 23, 2008 | 06:07 PM
kutsujula's Avatar
you cant use the S300 with the s2000, it's only kpro. I'd go kpro over aem ems.
