Tuned: KW C38-91 and SOS VMount Build
Old Feb 16, 2015 | 04:35 PM
Moddiction's Avatar
Former Sponsor
I'd love to see the boost this will make with the v mount. Should be similar to a water to air setup.
Old Feb 16, 2015 | 07:57 PM
gnehc1's Avatar
In for results and the build thread.
Old Feb 16, 2015 | 10:17 PM
Mnstr2000's Avatar
This should be interesting, and I thought very hard about doing the same thing. The V-mount has a smaller intercooler than the Kraftwerks, SOS is 24X9.5X3.25 and the Kraftwerks kit is 27x12x3. The way I saw it the V-mount has potentially better pipe routing and pipe size, and this might be a less restrictive overall intake path, even with a smaller, possibly more restrictive Intercooler.
Old Feb 17, 2015 | 12:40 AM
MARK AUS S2K's Avatar
Hey mate I love the V-Mount set up! but I thought Air/Water cooled S/C set ups are more efficient and produce more power? Surely the air will be cooler if water is added through the cooler rather than just air?
So the top radiator will be air/air for the S/C and the bottom with be the sock radiator with the two fans?
Does anyone know why KW don't use air/water? Man I would love the V-Mount but Im just worried I'll lose power.
Old Feb 17, 2015 | 04:16 AM
Redline S2K's Avatar
Good luck man. I really hope this works for you. I was really interest in doing the same but didn't think the kits would work together.
Old Feb 25, 2015 | 11:33 AM
jaundice's Avatar
See second post. Tuned the stock setup to have a baseline for when I change to the VMount.
Old Feb 25, 2015 | 11:53 AM
SlowTeg's Avatar
Originally Posted by jaundice
Also, tuned very conservatively, with VTEC at 4200 and peak timing at 115 degrees.
Dayom.. you think that's conservative?
I'll assume you meant 15 degrees.
Old Feb 25, 2015 | 11:59 AM
jaundice's Avatar
Oops. Yes, 15 degrees..
Old Feb 25, 2015 | 12:23 PM
Moddiction's Avatar
Former Sponsor
Holy crap that makes a lot of boost!! Should make a good bit more with the Vmount I would think as well!
Old Feb 25, 2015 | 04:25 PM
jaundice's Avatar
Yeah, talking with tuner, he wants me to use e85 or race gas if its going to make more than 17-18 psi with the VMount at less than 8500 rpm.
