tunes on 91 octane?
Old Jul 17, 2011 | 10:45 AM
sheepey's Avatar
Default tunes on 91 octane?
Greetings all,
So lately i've been stuck on if I want to run E85 or good ol So Cal 91 octane fuel. I was trying to find what kind of power people make on pump, but everything I see is on 93 octane, which we don't have. Was wanting to see some setups/power out of 91.
Thanks,
Alex
Stock compression, stock engine besides valvetrain.
Old Jul 17, 2011 | 10:50 AM
passmans2kny's Avatar
stock compression, built motor with low comp pistons? but with ur set up i say go e85
Old Jul 17, 2011 | 10:52 AM
*JG*'s Avatar
I think your 91 will yield less power than the E-85 by far but I've also heard that the E-85 has inconsistent mixtures unless you buy it in bulk out of the same batch. Maybe I've been misled on the E-85 deal so if I have set me straight!
Old Jul 17, 2011 | 11:42 AM
DFWs2k's Avatar
you are right, it varies a lot more in blend/quality from batch to batch than pump
that being said, i haven't read of any problems due to that
Old Jul 17, 2011 | 12:16 PM
Suzuka_Joe's Avatar
I made 423/261 on 13psi with a Mase kit and 91 gas with ethanol mix. I forgot to fill up on good 91 or 93. I run both 91 and 93 in it now though depending on what's available
Old Jul 17, 2011 | 01:04 PM
S2K-F8's Avatar
I'll probably get flamed for this...but here's my most recent (11 days ago) dyno sheet. This was first WOT pull. I think we hit 535hp/355tq on the best pull, but I was running out of fuel on the top end.
2004 S2K
91 octane - standard correction factor (I'm in Denver, no I didn't look at the uncorrected numbers)
Full-Race GT35R turbo kit
ID1000cc's
Hondata K-Pro
stock bottom end
Alaniz PnP head
Scott-
Old Jul 17, 2011 | 04:00 PM
sohc_mshue's Avatar
Check out Worldwideracingfuels.com . They are in VA and will make whatever mixture you want including ethanol with pump gas and with race fuels.
Old Jul 17, 2011 | 05:25 PM
*JG*'s Avatar
Yeah, they are at Bremo Bluff about 30 mins away from me.
Old Jul 17, 2011 | 08:46 PM
07GPW's Avatar
tuned on 91 (as we dont have anything else) 421whp 308wtq at 12.5psi of boost im running a ptuning kit. Motor is stock.
Old Jul 17, 2011 | 11:43 PM
riceball777's Avatar
you can make probably from 50%-100% more power on e85. e85 is the same to about 110 octane which is usually good enough to max out your turbo as long as your engine/clutch is strong enough to take it.
on my s2000 i make about 330whp with my ball bearing 50trim. on e85 or race gas you canmax out the turbo to about 500whp.
on my evo i make about 400whp on 91 octane with a full race twinscrool HTA gt35r kit, but with e85 you can max out the turbo to about 700awhp
