Tuning with Emanage
Old Jan 2, 2006 | 03:55 PM
Trip's Avatar
Default Tuning with Emanage
I am doing the whole tuning on my car myself without a dyno since I do not have access for one. I am using an emanage with the additional injector map.
I played with the injector map a little and only tuned 70%-100% TP% to get a "good" A/F graph. I assume there isn't much to tune more then increasing/decreasing fuel in my case apart from altering the vtec.
To get my A/F rights, i used another graph of a 5.5psi setup as my base graph(i still need minor tweeking to get it right). Do you think I can gain some more horses if i get richer by # across the whole rev range since i am running more PSI (7psi)?
Here is the graph I followed. (Thanks Juan )
https://www.s2ki.com/forums/index.php?act=m...mage&img=163294
A/F graph (logged with a wideband datalogger and plotted using excel)
Blue: without tune
Red: with present tune
Green: 5.5psi Base graph.
Injector map
When i get WOT complete i am planning to tune 30-50 TP% and 50-70 TP%
Any Comments welcome
Old Jan 5, 2006 | 08:54 AM
Trip's Avatar
Any help ?
Old Jan 5, 2006 | 06:11 PM
mase1's Avatar
you're too lean. you should be at 11.8-12.0:1 in boost.
Old Jan 5, 2006 | 06:26 PM
Slows2k's Avatar
Agreed. With the 440's and no FMU 12-12.5 was the best I was seeing at WOT 5500-9000rpm.
Old Jan 5, 2006 | 10:51 PM
folex187's Avatar
I would recommend you tune with manifold pressure and not TPS. I was seeing 11's with 440's but I was leaning out at 8900 to 12.7. After the addition of the AEM FPR which is 1:1 I was 11's accross the board.
Old Jan 6, 2006 | 11:01 AM
Trip's Avatar
Interesting observations. thanks
more questions
1)When you say "you should be at 11.8-12.0:1 in boost" , my first psi starts at 3000rpm going linear up to 6.9psi at redline. Should I be in the 12
Old Jan 6, 2006 | 03:44 PM
Slows2k's Avatar
Try this way to not cut the harness.
Old Jan 6, 2006 | 06:15 PM
folex187's Avatar
Slow- What did you use to stick in as prongs? I plan on making something like that to return from the RC harness to pass emissions. Or HOPEFULLY pass emissions..
Old Jan 6, 2006 | 07:28 PM
Slows2k's Avatar
Male terminal pins from a Honda pin terminal repair kit.
Old Jan 7, 2006 | 02:15 AM
Trip's Avatar
Fom where can i find these "Honda pin terminal repair kit"
Hard top guy ?
