Tuning with Emanage
Old Jan 7, 2006 | 05:59 AM
Slows2k's Avatar
HTG can get it for you, The kit has many pin styles included. I'll have to find the pin's part#, you'll also need a set of specific crimpers to properly crimp the pins.
The pin kit is around $500 retail, and the refill pins are about 25$ a pack.
Old Jan 7, 2006 | 05:33 PM
Trip's Avatar
$500 is not worth it IMH to save the engine harness.
I did some more tuning today and it got all messed up.
I noticed that i get more PSI during the day (7.4psi), then I get at night(6.6psi) Since i am using the Comptech FPR and it works on boost, Fuel delivery is changing from night and day. Now I get to understand why i should tune with manifold pressure and not TPS.
Old Jan 10, 2006 | 06:32 PM
revhi's Avatar
Trip can you email your current settings to me. Im not messing much with the car now until spring, but Id like to see your progress.
On my last tuning session, with the emanage and stock injectors, I was maxing out the injectors to get 11:1 across the board. I was also running to rich where I was tripping a CEL every couple days.
I was told by the tuner , the main problem was narrowed down to the Comptech rising rate FPR conflicting with the emanage. It was to hard to adjust it properly without a fuel pressure gauge. Also, throwing in VTEC adjustment at the time wasnt to fun either.
Im back to just the map clamp now for the mean time. Hoping to change to 9psi, 550cc, new FPR and AEM come spring.
If you can figure out safe and reliable settings with the emanage, let me know. It will save me some major time and money.
Old Jan 11, 2006 | 12:42 AM
Trip's Avatar
pm me your email .
Old Jan 11, 2006 | 07:20 AM
stphotographer's Avatar
Subscribed, I was also planning on tuning with the stock injectors and emanage next spring.
Will I have to replace the Comptech FPR with a 1:1 FPR like the AEM?
Old Mar 11, 2006 | 09:19 PM
revhi's Avatar
All right, got a new test pipe so Im guessing thats why my cars running 13.5:1 all of a sudden.
Started messing with the emanage a bit more. I zeroed out all the settings except the map clamp. The only settiings I changed where in injector maps. I added a bit a fuel from 50% throttle and on and 4500 rpm and on. I did a gradual increase up to 20% more fuel up top. The car feels great, and Im about 11:1 in boost again and no partial throttle hiccups.
My new question is, is it ok that I adjusted these settings and left the rest of the rpm and throttle range at zero? Also, is it ok that I didnt adjust air flow?
Old Jan 4, 2007 | 08:25 PM
SPEEDFUZION's Avatar
i hear bad things about emange how it work 4 u
Old Jan 4, 2007 | 08:29 PM
Dsgs2k3's Avatar
they actually have a plug an play clip now for the RC injectors so you dont have to cut the harness
Old Jan 4, 2007 | 08:34 PM
AROD's Avatar
i'm running over 500hp on my emanage
Old Jan 4, 2007 | 08:35 PM
Kwando's Avatar
that is what i used.
