turbo buildup, some issues
Old Nov 9, 2009 | 04:18 PM
20002point2l's Avatar
Default turbo buildup, some issues
hey guys, new to the forum.. ive tried the search key but cant come up with any legitimate answer to whats going wrong here...
ive been building up a turbo s2000 for a few months, its a hybrid greddy/inline pro kit with a inline pro hotside and greddy intercooler, emanage ultimate.. rc750s ect
the car is strong and makes 380whp on the dynapack dyno at 13psi.. but im having trouble with some sort of missfire/breakup ect around 6-6700 rpms.. any suggestions?? anyhelp would be greatly appreciated.. the car is running on the stock map sensor in its stock location with a greddy pressure sensor.
Old Nov 9, 2009 | 04:28 PM
dsddcd's Avatar
The stock map can only read up to 12 PSI but b/c it starts to breakup about 11PSI I would not go over 10.5-11PSI.
Not sure if this is your problem b/c you gave so little info but you should not this.
Old Nov 9, 2009 | 04:35 PM
thanks for the quick responce
it was still doing this breaking up at 8psi off the wastegate.. and only after the engagement of vtec. the map is clamped by the emanage at 2.65
Old Nov 9, 2009 | 04:57 PM
dsddcd's Avatar
Ah, Emanage, I can send you a base file to compair against yours to see if any settings got changed.
Old Nov 11, 2009 | 05:24 AM
does anybody have a definitive answer if you need the greddy map relocation kit if you are using the map clamp or not? there was one time on the dyno when vtec did not engage because the car was not warmed up enough and this did not happen and boost was not erratic.. still made the same power
Old Nov 11, 2009 | 05:37 AM
dsddcd's Avatar
Yes you still need a clamp.
Like I was saying before, without logs, more info on your setup there is no way to tell what is happening.
Old Nov 11, 2009 | 08:43 AM
I will try to get my hands on a xp laptop and save some logs on the street tonight.. It seems that the car is pulling timing bad once vtec engages then fixes itself around 7k and pulls as normal to redline.. Is the synape missing link a good idea considering I do not have the greddy relocation kit for the map sensor?
Old Nov 11, 2009 | 11:34 AM
Spoolin's Avatar
It sounds like your vtec engagement is set too low for your manifold. I'm assuming you have a log? If so, try raising your vtec engagement to around 7000 to see if it clears up. If it gets better at 7000 rpm engagement, just move it around a bit until its running perfect. Try lowering it a bit to say, 6900 rpm and see how it does. If its still breaking up there, go back to 7000 rpm and if its not completely perfect there, go to 7100 rpm. Just play around with it until its perfect.
Old Nov 11, 2009 | 06:16 PM
what would be the best way to adjust that if it is even possible considering im running an emanage ultimate? should i just suck it up and switch over to an aem?
Old Nov 11, 2009 | 06:36 PM
sbrodacz's Avatar
Banned
When I had my inline pro log mani my tuner actually turned vtec up 500 rpms instead of down. Have you checked your spark plugs? I had a misfire at 6600 and it ended up being a bad ground.
