Turbo Compression after engine rebuild
Old Aug 28, 2010 | 05:35 PM
aitrus16's Avatar
Default Turbo Compression after engine rebuild
Ok so quick question here..
S2000 with a Greddy Turbo Kit or a In Line Pro Stage 1 Kit..
Hondata Managed..
All is working well the engine needs a rebuild.
The engine was stock.. in the setup
During the rebuild there is the option of decreasing the compression to like 8:1 or keeping it at the stock 11:1
Whats the best move with these kits, I don't really want to lose HP/Torque
Sorry if this sound silly I just need to confirm.
Old Aug 28, 2010 | 06:03 PM
rosscoe21's Avatar
Not worth going 8:1 with the greddy kit imo. I would be looking for a different kit so I could crank kit up if I were going to go 8:1
Old Aug 28, 2010 | 06:17 PM
aitrus16's Avatar
What about with the In Line Pro Stage 1?
Old Aug 28, 2010 | 06:41 PM
aitrus16's Avatar
Could adjusting the boost work?
Old Aug 28, 2010 | 08:19 PM
m R g S r's Avatar
Run the lowest compression possible so you can make more power on pump gas (if you have the right sized turbo)
HOWEVER, there is a point where pump gas will only take you so far, then you have to switch to a fuel with more energy and better resistance to detonation.
Old Aug 28, 2010 | 08:44 PM
RedLineS2k10's Avatar
What #'s are you looking for?
Old Aug 28, 2010 | 08:48 PM
aitrus16's Avatar
ok so..
I start with an 11:1 and want to go to 16:1 the turbo boosts 5
If I rebuild to start with an 8:1 and want to go to the same 16:1 the turbo will compensate and boost 8
I am assuming a Greddy or In Line Pro stage 1 turbo setup..
Also will it performance the same or better?
Only going for pump gas as I want this to be streetable...
Old Aug 28, 2010 | 08:58 PM
Originally Posted by aitrus16,Aug 28 2010, 08:48 PM
ok so..
Did i read correct?
You want to build it for 8:1 or 16:1 compression??
Have you considered e85?
Old Aug 28, 2010 | 09:09 PM
aitrus16's Avatar
Sorry factery motor starts with 11:1 but I want to build the base motor to 8:1
With a turbo on a factery motor at 11:1 I asume you can get 16:1 with the turbo putting in the 5 extra PSI...
I want to knw if I will also get this after rebuilding the motor with 8:1 base will the turbo be able to bring it up to 16:1
Is it better to rebuild the motor to 11:1 or to 8:1...
Old Aug 28, 2010 | 10:34 PM
averageJoe's Avatar
you assumed wrong
you cannot just add compression and psi (boost)
mathematically, that doesn't even make sense
