Turbo coolant lines
Deleting the oem oil cooler donut and routing those coolant lines to turbo but which is the return and high pressure line?
https://cimg0.ibsrv.net/gimg/www.s2k...bdec6394c4.jpg |
I did this as well. The line coming out of block by oil pressure sender unit is the Feed line It should go on the bottom plug of the EFR center housing. the line infront of the timing cover is the Return line and should go on the top plug of the EFR center housing. Ideally they should also be cross-directional across the EFR housing as well (IE: Enter into bottom right of housing and Exit out of the Top left of housing).
Good thing i asked, i thought the black line was the feed line. Thanks for the help
