turbo install complete.. now rev issues :-/
Old Jun 13, 2010 | 12:13 PM
teamvalorracing's Avatar
Default turbo install complete.. now rev issues :-/
**EDIT: CAN REV UP TO 5k. must be a lean vacuum acceleration issue with the stock map***
so i installed my turbo kit i have been working on on and off for the last 6 months.
its loud as hell(3" back with resonator and dump) until i can get to the exhaust shop and have them weld a joiner from my temporary turn-down to my mufflers.
anyhow, there are no leaks, everything seems good. im on the stock ecu until i get to the tuner in 2 weeks, so im just gonna putt around town.
-i unplugged and blocked off the vtec oil pressure switch. did that a few days ago and didnt notice any issues though.
-still on stock injectors, stock map sensor, even still have the stock 02 installed right by the wideband practically.
what could this issue be? no new CEL besides the one i have had from removing the air pump but i did that 6 months ago. is the ecu so sensitive to any boost pressure that when the map gets to 0 and could possibly go over it starts to pull timing or something? im getting breakup at about 10 vac and about 15.2-15.5 afr.
advice is much appreciated.
Thanks!
Old Jun 13, 2010 | 12:22 PM
PsykotiK's Avatar
what are u getting tuned on? i wouldnt drive it untuned either.. i can see it breaking up to if your still on the stock map because you might be boosting past what the map can read
Old Jun 13, 2010 | 12:30 PM
Vi3tBoy's Avatar
I wouldnt try anything until it's tuned. Why risk the money you put into it?
Old Jun 13, 2010 | 12:40 PM
the breakup is getting cause by lean acceleration conditions while still under vaccum, not even to 7mm of vacuum at that. its like 15.2-15.5 AFR.
i CAN accelerate up to 5k if just light throttle. just didnt notice it before. anymore than light throttle i get breakup. which is expected.
i have the aem v2 ecu and 1000 ID injectors and a 3 bar all ready. i have even bi-wired all my sensors and injector plugs so when i get to the dyno, i just plug everything up, and let the turner do his thing. if i had some idea of how to setup the aem and get a basemap on and running, i would do that in a heartbeat, but i dont know where to begin. im the builder, no computer wiz here. lol
Old Jun 13, 2010 | 12:41 PM
Ek_Jak's Avatar
im pretty much on the same boat as you right now. just installed my turbo kit and running open downpipe with stock injectors and stock ecu right now. i dont drive it but im gonna drive it down the street to get my exhaust done, then trailer it to get my car tuned. i haven't started it yet but im guessing if you drive slow and shift like at 2-3k rpm, you'll be fine with the stock ecu and injectors.
Old Jun 13, 2010 | 12:47 PM
08s2000CRbackinblack's Avatar
you can rev up to 4 or 5 rpm to get to a shop, just dont have the pedal more than 15-20% and the turbo wont make boost.
Old Jun 13, 2010 | 12:50 PM
DFWs2k's Avatar
there is a (NA) basemap on the aem already/downloadable to the aem, most tuners will also send you a basemap to have your car drivable to them
Old Jun 13, 2010 | 12:54 PM
metros's Avatar
^^^Truth. I am pretty sure the AEM comes with a basemap. Check into that. I still wouldn't drive it hard but that'll be safer than using the stock ecu.
Old Jun 13, 2010 | 01:08 PM
^heard that. i just called my tuner and hes gonna call me back. might have me setup the aem and injectors/3bar before i go to him. its about a hour and 40 minute drive.
Old Jun 13, 2010 | 09:06 PM
jb34304's Avatar
I am only driving it straight from the shop to the tuner... I just threw in 4k for a fresh engine but still. Even on the stock build I wouldn't have taken that chance.
