Turbo kits... easy to reverse or uninstall?
i'm certain that SC's (especially Comptech) is something that can be reversed easily if need be... but wondering if say, the inlinepro or lovefab kit is something that can easily be uninstalled...
for what? inspection? its kind of a pita to swap out all the fuel stuff back to oem along with the exhaust and all the sensors etc. that you removed....
just get some shop to do a shady obd II inspection wink wink
It depends how crazy the setup is. My car would be a BITCH to put back to stock. I mean - it'd suck quite a bit. A lot depends on what is involved - if you're running stock compression and a piggy back, it'd wouldn't be too bad.
When you start relocating things and pulling stuff out (like brackets, air pump) and trimming bumpers, that's when things start to go past the point of no return.
My car would be a BITCH to put back to stock too. because battery is relocate, teh front had to be cut, to fit the intercooler, fuse box relocate, wire harness was cut, and air pump and all other hoses were remove, and more.... so my car will be with me for a longggggggg time =)....
1. live or have property where there is no smog regulations
2. buy an new car and not worry about it for 5 years
3. take everything out once every other year
4. or whats already stated above
