Turbo Manifold Question
Old Nov 26, 2007 | 02:31 PM
-DOZER-'s Avatar
Default Turbo Manifold Question
So I
Old Nov 26, 2007 | 02:53 PM
Asura's Avatar
Wastegate.
Old Nov 26, 2007 | 08:48 PM
-DOZER-'s Avatar
So what if your turbo has an internal waste gate? Can you use that port to tap a by bass valve back into the exhaust?
Old Nov 27, 2007 | 01:43 AM
s0rted's Avatar
^ as such your wastegate IS a by-pass valve that opens to vent excess exhaust gas (either back in to the exhaust or to atmosphere) when you reach a given level of boost. If you just route that pipe back into the exhaust you'd lose all the flow that is meant to spool up your turbo. Ideally youd want to do away with it altogether if you have an internal wastegate.
Old Nov 27, 2007 | 11:24 AM
passmans2kny's Avatar
go external and dump to atmosphere, only way to go
Old Nov 28, 2007 | 05:59 PM
J'sBlackAP1's Avatar
S2000 open wastegate sounds NASTY
Old Nov 28, 2007 | 06:07 PM
Soul Coughing's Avatar
i want to throw a little muffler on my dump tube and see if it sounds any different
Vent to atmosphere is much better for higher boost setups because it prevents as much boost creep!
Old Nov 28, 2007 | 07:58 PM
Spec_Ops2087's Avatar
^^Prob not a good idea, with the full race mani not having optimal placement for the wastegate, muffler might cause minor boost creep
Old Nov 28, 2007 | 11:39 PM
chairmnofthboard's Avatar
Old Nov 28, 2007 | 11:41 PM
I've seen someone do it. I think they used a streetbike muffler.
